My truck - 2006 GMC Sierra 1500 (Non HD) Z71 4x4, 5.3L SLT - Bose Audio...heated Seats...All power everything...On-Start
#1- Brake issue
Symptoms - 1st push of the break pedal has little to no resistance on the first 3/4's of travel. Immediate follow up pumps of the break pedal do increase the resistance and improve braking ability slightly. Seems like air in the lines kinda? There is plenty of brake fluid in the reservoir. The truck is also throwing ABS wheel speed sensor codes. So i feel like there may be more than one issue possibly. The back breaks are drum style.
Someone suggested that the first half of brake pedal travel usealy engages the rear brake system. I plan to replace the ABS sensors, but other than that where do I start? Also, right about the same time this issue presented it self I noticed my parking brake would no longer engage..maybe that is related?
#2 - Electrical Feed back noise through the audio system.
Symptoms - This issue is intermittent..but while playing music sometimes a high pitch noise comes through my speakers and its intensity corresponds with my engine rpms. The intensity of the noise is not affected by adjusting the volume other than completely turning it down. Bumps in the road cause this issue to come and go. I have no idea where to start with this one...some many wires!
#3 - Dimer knob adjustment shorting out
Symptoms - The knob that controls the dimming of dash/gages lighting is temperamental...I figure i just have to replace the module..but I am listing this is case anyone thinks it may correspond with issue #2. When it is acting up, if I smack it or adjust it...sometimes it seems to affect the high pitched noise..but since it is an impedance style control that is probably the only reason I hear a difference....I am assuming. The two issue can and do occur separately as well.
Thank to anyone who reads all this and has any advice...
Question
chips-ahoy
Hello,
I have a few issues I would like help diagnosing.
#1- Brake issue
6 answers to this question
