Do you have the sa's running off an amp or the deck? If an amp what wattage are you hitting them with? I know the sa's are only 2.75 inch soooo...not much kick to them....but do you notice any extra kick from them?
I'm running pioneer comp sets in the front and I really can't put my finger on it...but I just don't feel the punch from them. 6.75 speakers and I know vs all the other brands I'm not on the upper scale but feel they lack a little. Maybe I need to do like you stated and fully deaden the door. I have them IB and foam ringed so the audio doesn't escape between the door and panel...looking forward to the build on your system .. Always curious on what ppl do to the same vehicle I have...
Oh on the sa's. Did you leave the cap on the sa or are you using a crossover for them?
Sent from my Nexus 6P using Tapatalk
No amp... yes it has extra kick.. but like you said it's just 2.75"... I left the cap that came on the SA's but I think it could benefit from a crossover. I never used an IB but I hear that could be causing the muffled sound... I also did not think about foam rings... where did you yours?
Share this post
Link to post
If you have or are getting 6.5 speakers you can use these. There are some vids on you tube on them
http://www.mobilesolutions-usa.com/store/p878/F.A.S.T._Rings__3-Piece_Foam_6.5"_Speaker_Enhancer_Kit.html
https://www.youtube.com/shared?ci=T5fAQUcLuwM
Mine are 6.75 so the don't make that size. I went to home depot and got the foam strips you can seal windows with and made my own. A little crude but it does the job
Share this post
Link to post
Yeah I was just looking at them on amazon... I got 6.75" also.. so lowes here I come. :) (home depot is too far away :P )
Share this post
Link to post
why 6.75 in the front doors instead of 6x9? And why coax instead of 4 way? Honestly curious bc you seem to know way more about audio than i do lol
Edited by 14tungstenLT
Share this post
Link to post
Personal preference mostly.. There is an argument for any way to go but here are my reasons.. circle speakers produce a more symmetrical sound. (I know this is subjective take if for what you will) also 6X9's tend to be more expensive. .. 4 Way vs 2 Way In a 4 Way you just get two extra tweeters.. that in almost all cases block the cone of the main speaker which in turn deflects the sound in unintended directions. I think the 4 way is more of a gimmick you know if 2 way is good 4 way must be better.. .and I use to think like that as well. I even have purchased 4 way speakers... but IMHO its not needed. Plus I got a good deal on the 2 pair I bought it was $60 cheaper than crutchfield.
Share this post
Link to post
Awesome thanks for the info. I think I'm going to go a similar route.
Share this post
Link to post
Coax are perfectly fine. 4 ways are more hype than anything. If you get a coax with the woofer and a tweeter and a good reviewed set your good. Reason a went with components is to put the tweeter on the dash and have the lows...well down low lol. I am running front dash sa's, tweets right next to a pillars angled up about 45° aimed slightly at the windshield and the woofer in the door. Soon I will be adding a DSP so i am able to tune the system for the freqs each speaker is made for. Ex is the woofer 70~80 - 3800 hz, dash 250,300- 6-7000hz, and the tweet from 4000- up. Letting the speakers do their own job instead of taking everything in let's them work more efficiently and sound better. Plus I want time alignment for when I'm alone in the truck
Share this post
Link to post
I might... later down the road get a DSP and or amp for the door speakers... I did not do component because i wanted factory look and easy of installation also the reason why I got the SA's because it was the closest in size to factory... btw it's not a perfect fit you got to wiggle it in there and use the screws that come with it because the screws that came out will not work.
Share this post
Link to post
Lol I put em in tonight. Waiting til tomorrow to button everything up. Yea they are off by maybe 1-2 mm and that makes them a bit tight. I listened briefly to some songs and can tell the difference. Much better
Share this post
Link to post
Want to give an update... thanks to Jeff5347 for the idea here are the install pictures of the foam rings..
Rear door speaker
Front door speaker
Share this post
Link to post
Rear door speaker
Front door speaker
Those look good. Where did you get the foam? Looks like it was a flat piece you cut in a circle. How did you get them to stick.
Def interested in how you got this done. Looks way nicer than mine lol
Share this post
Link to post
Got it from Lowes.. its air conditioner weather stripping and I used loctite spray adhesive (Light 100). On the rear doors I used a razor knife and split it in half and the front I just used it as is, that's why its thicker.
Share this post
Link to post
whats that do? focus the sound into the cabin instead of leaking between the door panels.
Share this post
Link to post
  • Similar Content
    • By Bkapanka
      I just bought my first newish truck, being the 2014 Silverado 2wd z71 lt. It’s got the crew cab with 5.3l under the hood. I’m currently stationed at ft Stewart ga.
      Im just looking for some help or some advice on some upgrades I’d like to do to this truck and which products might be the best.
      - I’d like to change the headlights and fog lights from stock.
      - Put a leveling kit and some new (bigger) a/t tires on it and not sure what size being
      2wd.
      - Change to an aftermarket air intake.
      - Do something about the shitty stock speakers (without Bose). Wether it be new door speakers and sub(s). Or be just subs and have a separate amp just for door speakers. Do I need a processor to hook up to stock 8” head unit.
      - How do I add any app or navigation to this stock 8” head unit
      - Exhaust?
      - How to get more performance from the truck.
      Anything would help,
      Thanks
    • By SilveradoKeydet11
      Hey all,
      I have a 2017 LT 5.3 Z71 that just turned over 10k miles.  I've never had a truck under warranty so I haven't jumped into many mods yet (did an intake tube and hoping for an exhaust soon though).
      Trucks/jeeps I've had in the past I've upgraded the transmission pan to hold more fluid/cool better, on my Tahoe I did the same to the rear differential cover for toughness and cooling ability.  I've never had a new truck but plan on holding onto it for a long time so my thoughts are longevity/preventative/bulletproofing the drivetrain.
      Anyone have thoughts/experience/opinions?
      Thanks!
    • By Albatross696
      Hey guys. So I just bought an 03 1500 LS and I hate the look of the steering wheel. My buddy has an extra wheel from his 08 1500 (which I much prefer). Is there anyway of swapping the second gen wheel into my first gen? Thanks for your time.
    • By sschulze
      Replacing Bose factory 6.5" subwoofer in the center consol with a JL audio 6w3v3. I have seen many people talk about doing this but have never actually seen anyone follow through. I also replaced my rear door speakers. Factory size is 4x6 and I put in 6x8.
      Made tempelate of speaker size and traced onto the truck door with sharpie. Then used tin snips to cut out the hole. It was super easy and there is nothing back there to get in the way. Then made a mounting ring out of MDF and a jig saw. Painted it black and put a foam sealer on it which pulled tight when I mounted the speaker. I did notice a better sound quality when I added the 6x8 over the 4x6. I swapped because I lost sound out of my back right speaker and thought why not throw a bigger speaker in there.
      I will be installing the JL 6w3v3 with the JL jx250 amp this week and I will post pictures and let anyone know how it turned out. Obviously it's not a 10 or 12 under the rear seat but I think it will add a much better sound overall. Not looking to wake the neighborhood. I have read many places it's is "sooo complicated" to get to the Bose sub in the center consol why bother with it. Not true at all. It took 25-30 min to get the entire console out and pull the sub.
    • By laaubin
      Hi,
      I'm relatively new here so forgive me if this has been covered.
      Does anyone here know the items required and the part numbers to upgrade the OnStar Nav radio (IO5) to the full Nav (IO6) system?
      I've seen where it's only a cable and in other places you need to get a number of parts.
      If anyone has any experience with this mod I would really appreciate as much info as possible so I can go ahead with this mod.
      Thanks ahead of time for any help and info.
    No registered users viewing this page.
    Jaypin76
    Jaypin76
  • Who's Online   60 Members, 0 Anonymous, 243 Guests (See full list)
