DDDDDMORGAN Posted January 4, 2017 Share Posted January 4, 2017 Just came home with a new to me 1996 K2500. The dome light doesn't come on with the door nor with the dimmer control. I've been driving a Ford for a long time so maybe it's new owner ignorance. Link to comment Share on other sites More sharing options...
drenolov Posted January 4, 2017 Share Posted January 4, 2017 Just came home with a new to me 1996 K2500. The dome light doesn't come on with the door nor with the dimmer control. I've been driving a Ford for a long time so maybe it's new owner ignorance. There is a button by the headlight switch check that Sent from my LG-H830 using Tapatalk Link to comment Share on other sites More sharing options...
DDDDDMORGAN Posted January 4, 2017 Author Share Posted January 4, 2017 Drenolov, I just found a manual online and saw about the button, I braved the cold and nothing. I probably have a burned out bulb. It can wait till warmer times ;-) Link to comment Share on other sites More sharing options...
barry G Posted January 4, 2017 Share Posted January 4, 2017 the auto activate when door opens is on the left side of dash. The wear down for those switches is wiggling sloppy or going cockeyed. Would rather it stay off than on.. the fail is two ways. you can try smacking that see what happens. That is a surprising big circuit. Even the doors had lamps. I fixed mine all up once, looked like a circus with all the lamps working. I removed the door lamps,they were a bit much. Link to comment Share on other sites More sharing options...
DDDDDMORGAN Posted January 4, 2017 Author Share Posted January 4, 2017 Well after the above advice I checked and lo and behold I don't have a switch! I think that explains it ;-) It will be a fix when the weather gets decent. Link to comment Share on other sites More sharing options...
