Few Newbie Questions
8 replies to this topic
#1 PayTul
PayTul
  • Member
  • 17 posts
Posted 03 January 2017 - 10:31 PM
Ok guys, feeling like an idiot on a few things and not finding answers...sorry if my search skills just suck.
1. Just noticed looking in the manual tonight for other answers that the 6.2L recommends 93 Octane...haven't been doing that this first 1300 miles. Guess I'll switch, just wished I had noticed before I filled up tonight. I assume there isn't any damage done.
2. Auto high beams. Maybe I am just not used to it, but I am not liking it. When and where I drive at night I swear they are switching back and forth every 5-10 seconds. Not sure if it is a distraction to other drivers but it is me. Can that be disabled?
3. Looking through the settings menu on radio for answer to the high beam issue, I turned on the 'Easy Entry'. Totally screwed up seat settings from where I thought I had it set. Reset seat and turned off easy entry. Still messing up seat each time. Any trick to a good reset of that?
#2 smrr1
smrr1
  • Member
  • 675 posts
  • Name:Seth
  • Gender:Male
  • Drives:2015 silverado 5.3 LT Z71 crew/short
Posted 03 January 2017 - 10:36 PM
Should be no long lasting issues with the gas in the 6.2. Got nothing for ya on the other ones.
current ride
2015 Silverado 1500 LTZ71 ccsb 4x4 5.3
5%/35% tint, gm underseat storage, gm bed extender, spray on liner, snuglid sl, 1.5 level
32 other gm trucks and mustangs sold
#3 Coby7
Coby7
  • Member
  • 869 posts
  • Name:Terrance
  • Gender:Male
  • Drives:2011 Silver Silverado ext cab
Posted 03 January 2017 - 10:48 PM
Have you noticed any pinging? I believe it recommends 93 when pulling or high altitudes you should be good with 87 otherwise if you don't hear detonation ping.
#4 PayTul
PayTul
  • Member
  • 17 posts
Posted 03 January 2017 - 10:49 PM
i actually noticed it pinging a little a few days ago, but nothing real consistent.
#5 amxguy1970
amxguy1970
  • Member
  • 814 posts
  • Gender:Male
Posted 03 January 2017 - 11:17 PM
87 won't hurt it, they can run just fine on 87 with just a littler reduction in performance (maybe a mpg or two and about 10 or so hp). No biggie unless you are really pushing it and hearing pinging which usually happens under load in warmer weather or higher altitudes. Many such as our selves run 87 regularly.
Not familiar with number 2 but I would imagine it could be turned off. The third one should have been fixed turning it off, so not sure but a dealer trip might be due if it isn't going back to regular settings when you hit the memory button.
Tyler
#6 muddkatt
muddkatt
    Senior Enthusiast
  • Member
  • 1,283 posts
  • Gender:Male
  • Drives:2015 Silverado LTZ Crew Cab 5.3L, 2001 GMC Extended Cab 5.3L, 4L60E, 3.73-G80
Posted 04 January 2017 - 07:59 AM
Run the premium fuel like the manual says. While the 6.2 will run on the 87 octane, it is NOT good for the engine especially long term.  If you have an engine issue and GM pulls the data logs, you could end up with them denying warranty work. Is it really worth  saving $8 per fill up to take that chance? Not in my world it isn't.
#7 Bushleaguechew
Bushleaguechew
  • Member
  • 692 posts
  • Gender:Male
  • Drives:2016 Silverado 1500 LTZ Z71
Posted 04 January 2017 - 08:25 AM
You can turn off intellibeam (auto high beams) by flipping the high beam stalk on (forward) and off quickly. The little icon will vanish and the system is off. You can also temporarily shut it "off" by switching on your fog lights while the low beams are on. This will lock out your high beams from flipping on automatically.
As far as the seat adjustment goes without any more details from your my best guess is that you programmed the seat into the "exit" memory function instead of either driver 1 or 2. The function is designed to move the seat from driver 1 or 2 position into the exit position when the key is removed and the door opened and vice versa when the truck is started.
#8 PayTul
PayTul
  • Member
  • 17 posts
Posted 04 January 2017 - 01:09 PM
Thanks for the info!
#9 PayTul
PayTul
  • Member
  • 17 posts
Posted 11 January 2017 - 04:54 PM
worked on both accounts...thanks!
Reply to this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
