- 0
03 Suburban high beam indicator dimly light at all times
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 8 Members, 1 Anonymous, 908 Guests (See full list)
Question
topeltruckcenter
I have an 03 suburban, the high beam indicator stay dimly lit even with the key off and out of ignition. I sent the IPC in to get, that was the problem, they said there was nothing wrong with it bit replaced all the stepper motors, bulbs and transistor anyways, as soon as I plugged it in when I got it back the light was flashing and eventually stopped but remained lit but still dim. I've unplugged all 3 plugs on the BCM and the light remains lit, I've unplugged the multi function switch, no change, only way I can get it to go out is unplugging the dash itself, pulling the IPC fuse or disconnecting the battery. I also ran my own grounds to the 2 ground wires on the connector at the back of the IPC and light stays lit. I'm at a complete loss with this and am looking for where to go to next. Any help would be greatly appreciated! Thanks
1 answer to this question
