SierraMyst Posted January 28, 2017 Share Posted January 28, 2017 So 2016 Yukon XL Denali. So I have the digital DIC. Truck did something odd today. I got the low fuel notification at a 1/4 tank which it's never done before. Turned the truck off, ran an errand, and came back to the truck and no low fuel indicator again until the needle was closer to the E. Which is normal. Anyone experience this. The "long wheelbase" XL, Suburban has a 31.5 gallon tank. I'm just wondering... 1) When does everyone else's low fuel indicator turn on? And... 2) from the needle at the E, how many gallons does I take you to fill up? Mine was just at the E and it took 26.6 gallons. Is that pretty normal? Link to comment Share on other sites More sharing options...
azcreeker Posted January 30, 2017 Share Posted January 30, 2017 +1, interested in some feedback Link to comment Share on other sites More sharing options...
SierraMyst Posted January 30, 2017 Author Share Posted January 30, 2017 +1, interested in some feedback Apparently, no one puts gas in thier trucks. Link to comment Share on other sites More sharing options...
azcreeker Posted January 30, 2017 Share Posted January 30, 2017 Apparently, no one puts gas in thier trucks. I noticed really low traffic/replies on this forum, do you know if there is a more active forum to discuss 15 and up GM full size SUV's? Link to comment Share on other sites More sharing options...
markitzero Posted February 8, 2017 Share Posted February 8, 2017 2016 Suburban LTZ w/digital DIC. I haven't notice the 1/4 tank warning, mine always is down in the red when the warning comes on. Typically it fills with 26-27 gallons so 5 or so gallons remaining. Link to comment Share on other sites More sharing options...
seamus2154 Posted February 9, 2017 Share Posted February 9, 2017 2015 Denali XL ^^^^^ I have exactly the same report as Post#5. Don't think I ever got more than 27 gallons in after that light. Link to comment Share on other sites More sharing options...
seamus2154 Posted February 10, 2017 Share Posted February 10, 2017 I would consider it an odd event, or that the sender unit just hung up on the rod. If it keeps happening maybe check with dealer to see if there is a TSB. This did happen with the C6 corvette and there was a cause and fix from GM. But a one-time event I would just monitor it. Link to comment Share on other sites More sharing options...
Ekims Posted February 13, 2017 Share Posted February 13, 2017 On my 07 Denali XL there was a Fuel Used readout in the DIC. On my '17 XL Denali there no longer is this readout. I did notice that feature on a '16 I test drive. Am I missing something on my DIC setup or did GMC get rid of this feature. It seems to me the most important feature. You know your tank holds 31.5 gallons and the fuel used tells you how much you have burned, no need to panic with the low fuel gauge if you know how many gallons used! Link to comment Share on other sites More sharing options...
Michael Klug Posted February 16, 2017 Share Posted February 16, 2017 My light went on yesterday around the time display said 65 miles remaining to empty. Drove another 20 miles or so and filled it up w 27 gallons. Link to comment Share on other sites More sharing options...
markitzero Posted March 10, 2017 Share Posted March 10, 2017 On my 07 Denali XL there was a Fuel Used readout in the DIC. On my '17 XL Denali there no longer is this readout. I did notice that feature on a '16 I test drive. Am I missing something on my DIC setup or did GMC get rid of this feature. It seems to me the most important feature. You know your tank holds 31.5 gallons and the fuel used tells you how much you have burned, no need to panic with the low fuel gauge if you know how many gallons used! Mine has the digital DIC with/HUD but assume the standard is similar. Fuel used is there, you just have to go in and configure the display to show it. Link to comment Share on other sites More sharing options...
Ekims Posted March 10, 2017 Share Posted March 10, 2017 Mine has the digital DIC with/HUD but assume the standard is similar. Fuel used is there, you just have to go in and configure the display to show it. But yours is a '16. Pretty sure they changed it for '17's unless somebody can tell me otherwise. I wish It was there, i think it is the most valuable measurement. Gallons used will let me know better than the gauge how much I have left. Link to comment Share on other sites More sharing options...
markitzero Posted March 11, 2017 Share Posted March 11, 2017 But yours is a '16. Pretty sure they changed it for '17's unless somebody can tell me otherwise. I wish It was there, i think it is the most valuable measurement. Gallons used will let me know better than the gauge how much I have left. Here is where I found it on mine... press the left button on the right side of the steering wheel on go down to settings. Down to where it lists pages and press right. This is where you activate and deactivate what information is shown as you scroll through the DIS readouts. The speed limit is great with the HUD. Displays the speed limit below your actual speed. Link to comment Share on other sites More sharing options...
Ekims Posted March 11, 2017 Share Posted March 11, 2017 Here is where I found it on mine... press the left button on the right side of the steering wheel on go down to settings. Down to where it lists pages and press right. This is where you activate and deactivate what information is shown as you scroll through the DIS readouts. The speed limit is great with the HUD. Displays the speed limit below your actual speed. I appreciate your help but it's not there, already tried that. I do use the speed limit on the hud (has yet to help,drive at the limit, ) Link to comment Share on other sites More sharing options...
markitzero Posted March 11, 2017 Share Posted March 11, 2017 I appreciate your help but it's not there, already tried that. I do use the speed limit on the hud (has yet to help,drive at the limit, ) Strange they would remove it. Link to comment Share on other sites More sharing options...
Ekims Posted March 12, 2017 Share Posted March 12, 2017 Strange they would remove it. Very strange indeed but it's not there. Only timer. I asked a SA and he said the did away with it. I can't imagine why because it seemed like a valuable function. Link to comment Share on other sites More sharing options...
