Sign in to follow this
Gorehamj
Is Your Silverado / Sierra HD Steering a Little Off?
John Goreham
3-7-2017
2016 Silverado HD owners continue to struggle with steering issues despite a Chevy TSB now on version "D." This is not news to many GM-Trucks.com members who have reported the issue in our forums. The TSB, #PIT5501, covers the general topic, "Steering Feels Loose / Excessive Lash / Fluid Leak At Lash Adjuster." Owners have reported that the fix does not seem to stick. A recent detailed overview by Mary Conway at Torque News, laid out the many woes customers are reporting widely on multiple forums. As the video below shows, the problem may not be limited to just GM's Silverado, but also the GMC Sierra & Denali, which of course has a lot of shared components.
If this is a problem you had and have resolved long-term, we'd like to know about it in the comments section below.
https://www.youtube.com/watch?v=eSTu50h63No
Share this post
Link to post
I just traded a 2016 Sierra Denali 3500 HD Duramax Crew Cab 8'box, single rear wheel truck yesterday. Bought it 1/2016 and it had 17,600 miles on it. Only warranty work on the truck was the Loose Accelerator pedal when I first picked it up. I wasn't loose, but I took it in for the TSB/Recall anyhow.
I never had any issues with the steering being off or loose. I know it felt a little different than my 2015 Denali, but nothing out of the ordinary for the new system. I just picked up a 2017 Silverado LTZ 3500 HD Midnight Crew Long with the new Duramax.
Share this post
Link to post
My dad's 2016 is doing good.. might be 3k miles on it now.
I am an old steering box kinda guy, I do not like 87 subaru rally steer feeling in the big gmc...
but it is working just fine anyway.
Share this post
Link to post
Mine puked out a bunch of fluid and lost steering from 10-2 o clock... The dealer performed a TSB but didn't replace anything... They sent me down the road & I don't have much confidence in the fix. I'm expecting to be at the dealer sooner or later for another band aid... Other than this, the truck has been pretty solid.
Edited by 20Bowtie16
Share this post
Link to post
  • Similar Content
    • By thapatman54
      Hey guys. I have been driving a used 2007 Silverado Classic for about a year now. The truck has a regular cab, regular bed, 4.3L V6, and did not come with a tow package from the factory. After I started to realize I would need it for towing some smaller to medium trailers,  I got the basic 4 way package and hitch installed at U Haul this past December, and also installed a Hopkins 7-blade/4-pin piece to the wiring cable just above the spare tire. However, I also would prefer to hook in a trailer brake system to save on wear and tear on my brake pads when moving larger trailers that I might occasionally haul. While the standard 2007 Silverado Classic (it's really just a 2006 Silverado) that comes with a tow package comes with the wiring, the wiring to the STUD #1 fuse in my engine bay fuse box, which normally has the power to a trailer brake controller, is absent from anywhere I can see around the box on mine. I also notice that the wiring to the trailer brake output in my truck is not connected to anything, and is just an empty wire running back to the end of the truck.  STUD #2 is already connected under the box, which does not show the usual "install all the wires yourself" advice on most trailer brake controller videos from etrailer.com
      I am wondering if the red/power and blue/trailer brake wiring is hiding anywhere within any bundles and just needs to be connected together into the fuse box and to a trailer controller, or if I have to tap into my firewall and wire up everything myself.
      Here is a representation of the truck I have below:
      Here is the fuse box. Stud #1 seems to be used by the trailer brake controller's power wire, as most etrailer.com videos show these are already wired on towing equipped vehicles.
    • By Bkapanka
      I just bought my first newish truck, being the 2014 Silverado 2wd z71 lt. It’s got the crew cab with 5.3l under the hood. I’m currently stationed at ft Stewart ga.
      Im just looking for some help or some advice on some upgrades I’d like to do to this truck and which products might be the best.
      - I’d like to change the headlights and fog lights from stock.
      - Put a leveling kit and some new (bigger) a/t tires on it and not sure what size being
      2wd.
      - Change to an aftermarket air intake.
      - Do something about the shitty stock speakers (without Bose). Wether it be new door speakers and sub(s). Or be just subs and have a separate amp just for door speakers. Do I need a processor to hook up to stock 8” head unit.
      - How do I add any app or navigation to this stock 8” head unit
      - Exhaust?
      - How to get more performance from the truck.
      Anything would help,
      Thanks
    • By Merle vanGennip
      Heya folks,
      I have come across a 1993 chevy silverado 3500 with a swapped engine (502) I have little to no experience with cars. I've been looking at it with a mechanic who is considerably more experienced having worked on Cummins Diesels for a transport company. He's working on a truck of his own. I was trying to help him out by figuring out the firing order we've tried various ones, It doesn't appear to be misfiring but I have little experience with v8's so i'm not sure what a 502 or a 454 should sound like firing order-wise. I'd happily post a recording. Truck also has injection issues which means it needs a bit of help every time to start. It's also currently stuck in limp-mode as it will not exceed 1800rpm's. The computer has been 'tampered' with, presumably when the block was changed. It's currently with another mechanic who has a diagnostic system.
      Basically, I was hoping someone could post the firing order of a 502 and I could check when I get her back from the mechanic.
      Thank you all in advance
    • By mohnsy
      Hey everyone... recently switched from a f150 to my 2018 elevation, love the truck so far but wana do some mods..
      This post will be mainly on swapping the factory steering wheel to a leather one with volume control (gota have it lol)
      I got the base model in the pic below and just looking, who knows how to swap it and what it take to get it done.
      Also is it simply plug and play or will the car need to be reprogrammed to allow the controls to work with the radio.
      On another note if anyone has a good spot to get parts let me know. I got a few other projects I plan on doing such as
      Rear sear replacement from the bench to a 60/40
      Leatherseats.com replacements (after the bench replace)
      Tint (anyone got good brand reviews or experiences?)
      Possible change from flip front sear to consul (big job and expensive lol)
      I hope some one on here can help ill be sure to post pics as I get the project going.
    No registered users viewing this page.
    Ranco
    Ranco
  • Who's Online   88 Members, 2 Anonymous, 288 Guests (See full list)
