- 0
Please help with Codes on a 2003 Yukon SLT
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 14 Members, 1 Anonymous, 1,803 Guests (See full list)
Question
zmann96
I have a 2003 Yukon SLT 5.3l 4x4 auto, ( non flex fuel) I have been trying the pass my emissions test since last November. I had a code for the knock sensors. I replaced them and the has gone away. After that and before I went for the re-inspection I got a P1010 code. I put a new MAF sensor and cleared and drove a few hundred miles. The code came back along with P1072 and P0175. I had installed prior to the initial inspection a set of MSD high output coils, 8mm wires and new plugs. Since the P1010 and the P1072 and P1075 I've replaced the air filter when I replaced the MAF. The fuel pressure is OK. I've checked for air leaks before the intake manifold and replaced the intake manifold gasket but those I thought would cause a lean mixture and not a rich mixture ?? I do have an exhaust leak on both exhaust manifolds but not real bad. I did have the transmission rebuilt prior to my initial inspection. It has been getting around 20mpg on the highway not by the computer but by mileage and gas used. It has a slight rough idle but is not stalling. I'm thinking it may be the ECU ? I thought a leak in the exhaust would cause a lean mixture as well ? I hate to keep throwing money at things that are good. Any advice would be greatly appreciated.
4 answers to this question
