Barman84 Posted March 25, 2017 Share Posted March 25, 2017 i just purchased a used 2014 crew for a killer deal. But it left me with a lack of options. I have an io6 ready to go and as bad as I want to just pull the io4 out and slap the 6 in I'm sure it won't work that easily. I also have a backup car I am wanting to install and everything I've read says I just need to get the HMI programmed for it and it'll work. Now the question is once I get the HMI programmed can't they get the radio to work as well? Or does the radio itself need to be unlocked? Link to comment Share on other sites More sharing options...
srttotruck26 Posted March 26, 2017 Share Posted March 26, 2017 youll need the correct harness and a hmi programmed to go from io4-io6. It will cost you around 1500 from MVI or 2500 from a dealership. I went the cheaper route and it works perfectly. The aftermarket radio i bought was all plug and play. Check this topic:http://www.gm-trucks.com/forums/topic/196450-upgrade-io3-io4-and-even-io5-radio/ Link to comment Share on other sites More sharing options...
daort15 Posted June 30, 2017 Share Posted June 30, 2017 youll need the correct harness and a hmi programmed to go from io4-io6. It will cost you around 1500 from MVI or 2500 from a dealership. I went the cheaper route and it works perfectly. The aftermarket radio i bought was all plug and play. Check this topic:http://www.gm-trucks.com/forums/topic/196450-upgrade-io3-io4-and-even-io5-radio/1500 from MVI or 2500 from stealers?????? Buy me a hamburger And I tell you how to do it Link to comment Share on other sites More sharing options...
Carter8 Posted July 2, 2017 Share Posted July 2, 2017 It's not just plug and play unfortunately, your gonna need a hmi programmed specifically for your truck, contact mvi and they'll let you know what has to be done Link to comment Share on other sites More sharing options...
