- 0
P0172, P0175 too rich, 07 6.2 about to throw in the towel
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 17 Members, 0 Anonymous, 1,404 Guests (See full list)
Question
chucksrt
I have a 07 Yukon denali xl with 120,000 miles on it. I started getting a check engine light a month or two ago. I researched it and replaced items that are common to causing this issue. I didn't care if it was the fault or not because of the miles i just figured the new parts would help it regardless. I started by replacing the EVAP purge solenoid. That actually seemed to help me fill the tank to full better? I then replaced the mass air flow sensor, again, i have cleaned it but thought a new one wouldn't hurt. Then i replaced the MAP sensor. I know that they can be a common point of failure. It seemed to run better but still had the C.E.L. i took it to a friends shop and he wasn't much help. He pretty much looked it up on Mitchell and said it sounds like the fuel injectors are bad. I bought a used set of injectors and sent then to FIC to be cleaned and flow tested. I received them yesterday and installed them and on my maiden voyage the codes returned in pending. I am at a loss!? I am going to take it to GMC to look at ir bur i do not know what else to check. Any thoughts or have you run into a similar issue where something else fixed it?
Sent from my SM-G935P using Tapatalk
41 answers to this question
