- 0
98 K2500 'burb brakes
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 23 Members, 0 Anonymous, 2,050 Guests (See full list)
Question
Bullet_98
Greetings, I thought I would check here before I do something drastic. 1998 Suburban K2500 454 gas w/HD rear brakes. I've been spinning wrenches for over 30 years so I'm not a novice but this one has got me. The brakes haven't been right since I got it 3 years ago. I've done the following, new rotors, turned drums, new calipers, complete drum hardware kit, wheel cylinders, all three rubber lines, plus two master cylinders, one rebuilt, one new Delco. The brakes are still crap. There's two inches or so of free fall and I swear it speeds up, then they start engaging, it stops but requires a good bit of pressure to do so, way more than it should with hydroboost but not like manual. The back brakes are clearly doing the most work as it will slide the rear in gravel or a wet road if you grab them hard. I pull a 30' camper and have to pray to the brake controller every time I need to stop in a hurry which happens no matter how you try to plan and anticipate papaw's next move in front of you. There are no lights and they are still there, the light at ignition on. My best guess is the ABS box is somehow bypassing or leaking pressure between the front and rear circuit. If I adjust the back brakes until they start to scrub a little on the drum and I get in stop and go for a bit, they will pump up until they are too tight. My next move pending advice here is go to the older style non-ABS master cylinder and eliminate the box. A couple questions, does the box also do the job of proportional valve? If so I would need to add one. I've got 20 days until we leave again, any help or advice would be appreciated. Thanks
4 answers to this question
