NA8THEGR8 Posted May 24, 2017 Share Posted May 24, 2017 2002 chevy silverado 2500hd 6.0 truck randomly dies no rough idle, no lights, no error codes. Truck won't start up right after it dies but if I let it sit it will start up fine anyone else have similar issues or have any ideas and what it could be? Link to comment Share on other sites More sharing options...
Raptordude Posted May 24, 2017 Share Posted May 24, 2017 That is word for word what my truck did when my crank position sensor went bad Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Swimmer8366 Posted May 24, 2017 Share Posted May 24, 2017 That's what I would think it would be is a bad crank sensor..... Sent from my Z981 using Tapatalk Buy oem Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
Swimmer8366 Posted May 24, 2017 Share Posted May 24, 2017 When it dies check for power at the crank sensor..... Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
NA8THEGR8 Posted May 25, 2017 Author Share Posted May 25, 2017 Awesome thanks guys I think I'll just replace it tomorrow and see if that takes care of the problem Link to comment Share on other sites More sharing options...
Swimmer8366 Posted May 25, 2017 Share Posted May 25, 2017 May or may not need to do a crank shaft variation relearn. Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
Swimmer8366 Posted May 25, 2017 Share Posted May 25, 2017 Awesome thanks guys I think I'll just replace it tomorrow and see if that takes care of the problemI would check power before going through changing it. Because if you do than you get the famous flashing light than do crank learn and still dies your gonna be extra mad. And also if you replace it be careful because the seize up in the block. Twist it free first and gently pry her out. Do you know where it's located? It should be behind the starter. Starter has to be unbolted not removed just unbolted and moved out of way. Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
NA8THEGR8 Posted May 25, 2017 Author Share Posted May 25, 2017 I would check power before going through changing it. Because if you do than you get the famous flashing light than do crank learn and still dies your gonna be extra mad. And also if you replace it be careful because the seize up in the block. Twist it free first and gently pry her out. Do you know where it's located? It should be behind the starter. Starter has to be unbolted not removed just unbolted and moved out of way. Sent from my Z981 using Tapatalk My knowledge on engines is very limited I was going to have my buddy at a shop help me and as far as testing it never happens when I have the appropriate tools around and by the time we get them it starts again Sent from my E5803 using Tapatalk Link to comment Share on other sites More sharing options...
NA8THEGR8 Posted May 25, 2017 Author Share Posted May 25, 2017 May or may not need to do a crank shaft variation relearn. Sent from my Z981 using Tapatalk What does this entail? Sent from my E5803 using Tapatalk Link to comment Share on other sites More sharing options...
NA8THEGR8 Posted May 25, 2017 Author Share Posted May 25, 2017 What does this entail? Sent from my E5803 using Tapatalk NVM I found a pdf from napa online Sent from my E5803 using Tapatalk Link to comment Share on other sites More sharing options...
Swimmer8366 Posted May 26, 2017 Share Posted May 26, 2017 It's a computer reset between camshaft and crankshaft it's how our engines determine misfire Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
Swimmer8366 Posted May 26, 2017 Share Posted May 26, 2017 This is something any mechanical inclined person can do. Pull the start it's two bolts either 13mm or 15mm I can't remember than it's one 10 holding the crank sensor twist, pop. Grease new one around O ring and pop it back in bolt down plug in reinstall start. Reconnect battery. If someone taking there time. 20 minutes Tops I can do them in about 5-10. Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
Raptordude Posted May 26, 2017 Share Posted May 26, 2017 You don't need to re-learn it. On my 01 I replaced it and did not do a re-learn. I put it in over a year ago and it hasn't given any trouble. The re-learn is only so the computer can give you the correct code if the engine misfires for any reason down the road. To re-learn, you need to select re-learn procedure with an OBD diagnostic tool, jack it up, put it in Drive, and floor it till it hits the rev limiter. I really did not want to do that Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Swimmer8366 Posted May 26, 2017 Share Posted May 26, 2017 You don't need to re-learn it. On my 01 I replaced it and did not do a re-learn. I put it in over a year ago and it hasn't given any trouble. The re-learn is only so the computer can give you the correct code if the engine misfires for any reason down the road. To re-learn, you need to select re-learn procedure with an OBD diagnostic tool, jack it up, put it in Drive, and floor it till it hits the rev limiter. I really did not want to do that Sent from my iPhone using Tapatalk Some do some don't it's super silly... my 02 didn't my buddies 04 did. Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
NA8THEGR8 Posted May 26, 2017 Author Share Posted May 26, 2017 Some do some don't it's super silly... my 02 didn't my buddies 04 did. Sent from my Z981 using Tapatalk Thanks everyone this has been going on for about a month I'm very anxious to see if this corrects the problem Sent from my E5803 using Tapatalk Link to comment Share on other sites More sharing options...
