jrob56 Posted May 27, 2017 Share Posted May 27, 2017 Looking for the rear shock torque spec for top and bottom. I found all the front ones I needed but not rear. Thanks, Josh Link to comment Share on other sites More sharing options...
pgamboa Posted May 27, 2017 Share Posted May 27, 2017 Looking for the rear shock torque spec for top and bottom. I found all the front ones I needed but not rear. Thanks, Josh Following... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
07Softail Posted May 27, 2017 Share Posted May 27, 2017 just tighten them....You won't overtighten unless you have a 2'ft cheater pipe!! RT Link to comment Share on other sites More sharing options...
newdude Posted May 27, 2017 Share Posted May 27, 2017 85 ft.lbs. both the upper and lower fasteners. Link to comment Share on other sites More sharing options...
newdude Posted May 27, 2017 Share Posted May 27, 2017 just tighten them....You won't overtighten unless you have a 2'ft cheater pipe!! RT http://www.tangentlabs.com/clientuploads/Newsletter/August/Importance%20of%20Proper%20Torque.pdf Link to comment Share on other sites More sharing options...
jrob56 Posted May 27, 2017 Author Share Posted May 27, 2017 85 ft.lbs. both the upper and lower fasteners. Thank you sir, rear 5100s are on. Only about an hour start to finish. Link to comment Share on other sites More sharing options...
TheBlackPearl Posted May 28, 2017 Share Posted May 28, 2017 2 ugga duggas Link to comment Share on other sites More sharing options...
