Back in a Bowtie Posted June 16, 2017 Share Posted June 16, 2017 So my sweetheart just cracked the 50k mile point. What services should i do along with the oil at this point? i figure it's a good time to change the trans fluid and the transfer case fluid as well? Link to comment Share on other sites More sharing options...
Bassinz71 Posted June 16, 2017 Share Posted June 16, 2017 Im wondering about this as well. Im also curious if the trans should be flushed or just drop the pan and change that portion... Link to comment Share on other sites More sharing options...
sdeeter19555 Posted June 16, 2017 Share Posted June 16, 2017 Pan drop and filter... Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
crushNchowda Posted June 16, 2017 Share Posted June 16, 2017 Depends on driving style I think. For me I plan on doing coolant + differential fluid @ 50K, tranny @ 75k. Depending on when you last did it I would also check engine & cabin air filters. Link to comment Share on other sites More sharing options...
Sierra 5.3 Posted June 16, 2017 Share Posted June 16, 2017 I plan on doing cabin air filters every 20k, but that's because of my allergies and piece of mind. Too many photos of leaves and rat's nests. engine filter about 30k, check at 20k. Link to comment Share on other sites More sharing options...
Back in a Bowtie Posted June 16, 2017 Author Share Posted June 16, 2017 i have an Airaid and K&N cabin filter so ill wash both of those for sure. Didn't think of changing coolant and differential though. Link to comment Share on other sites More sharing options...
mookdoc6 Posted June 16, 2017 Share Posted June 16, 2017 Drop Tranny Pan! Flush and Fill replace filter on Tranny and the other aforementioned stuff......If you want to know I changed my Rear Differential out at 28-29K and it looked pretty good so I feel it's good to go 60-75K before it gets pretty rank. But I have no idea how or what you do with truck so it's up to you..... The only other thing I am concerned with is the dang plugs on GDI.......I just think it's laughable for these MFG's to claim 100K on Port Injection let alone GDI??????? I know somebody is going to say, "read your owners manual" the last 3-4 vehicles all told me 100k on plugs doubt GM decided to change that...... I also wouldn't hesitate to use 2qty cans of BG-EPR in crankcase follow directions and drain and fill......one has to be cognizant of the GDI! Link to comment Share on other sites More sharing options...
Back in a Bowtie Posted June 16, 2017 Author Share Posted June 16, 2017 one has to be cognizant of the GDI! yea i had a bad case of seafoam clogging my cats and fighting with my dealer to replace them. Not messing with it again. Ill just get the valves blasted at 100-150k Link to comment Share on other sites More sharing options...
mookdoc6 Posted June 16, 2017 Share Posted June 16, 2017 yea i had a bad case of seafoam clogging my cats and fighting with my dealer to replace them. Not messing with it again. Ill just get the valves blasted at 100-150k I hear ya! I talked to many a mechanics before I used BG-just recently on my vehicle and was extremely impressed. Never used Seafoam in vehicle and never would......Sorry to hear you ended up with problems. Link to comment Share on other sites More sharing options...
ShamrockShooter Posted June 16, 2017 Share Posted June 16, 2017 You can extend the life of cabin air filter by taking it out twice a year and banging the gunk out and vacuum with a shop vac Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Silverado-Hareek Posted June 16, 2017 Share Posted June 16, 2017 I hear ya! I talked to many a mechanics before I used BG-just recently on my vehicle and was extremely impressed. Never used Seafoam in vehicle and never would......Sorry to hear you ended up with problems. I did 2 BG inducation services on my truck and then started worrying about clogged cats. I asked my mechanic about it and he said it isn't a problem nor should it ever be. I still worried about it though and decided to to stop doing them every 15,000 miles. I have an oil catch can. I'll probably just see how the engine is doing around 100,000 miles and maybe do another BG service then. Link to comment Share on other sites More sharing options...
Silverado-Hareek Posted June 16, 2017 Share Posted June 16, 2017 Sorry for the side bar. Back to the OP, I have 45,000 miles on my truck. When I hit 50k I plan to change the tranny fluid and filter. I'll do my front/rear differentials and transfer case at 75,000 miles. Link to comment Share on other sites More sharing options...
ChevyMan2015 Posted June 17, 2017 Share Posted June 17, 2017 So my sweetheart just cracked the 50k mile point. What services should i do along with the oil at this point? i figure it's a good time to change the trans fluid and the transfer case fluid as well? What does your owners's manual tell you to do? Link to comment Share on other sites More sharing options...
sdeeter19555 Posted June 17, 2017 Share Posted June 17, 2017 What does your owners's manual tell you to do? Keeping in mind that most of us fall under the "severe" category in one way or another... Sent from my SAMSUNG-SM-G900A using Tapatalk Link to comment Share on other sites More sharing options...
Black02Silverado Posted June 17, 2017 Share Posted June 17, 2017 Trans pan drop and filter change. Both diff's change if never done before and transfer case change out as well. Link to comment Share on other sites More sharing options...
