Bootstrap Posted June 30, 2017 Share Posted June 30, 2017 Hey guys. I am completely restoring a 92 Chevy 1500 sport. It's a 4.3L with 5 spd trans. I have done several upgrades here and there and what I'm wanting to do is put an auto trans in the truck. Cld someone give me a list of what all I will need to do this? Any help wld b greatly appreciated. Thanks Link to comment Share on other sites More sharing options...
dnl_paterson Posted July 1, 2017 Share Posted July 1, 2017 Hey guys. I am completely restoring a 92 Chevy 1500 sport. It's a 4.3L with 5 spd trans. I have done several upgrades here and there and what I'm wanting to do is put an auto trans in the truck. Cld someone give me a list of what all I will need to do this? Any help wld b greatly appreciated. ThanksIMO, I would keep the 5 speed. The truck is geared for it, if it is the original rear end. If you put in the automatic, you will want to put lower gears in. It's probably a 3.08 now. You would need to upgrade to at least a 3.73 if you want any grunt with the automatic. Sent from my N9560 using Tapatalk Link to comment Share on other sites More sharing options...
barry G Posted July 2, 2017 Share Posted July 2, 2017 just needs shifter for your auto. ingenuity, or aftermarket. there may be a controller needed if electronic 4 speed auto. I have the v8 factory on nv3500.. 3.73 gear. not sure why they'd put tall gears on a bent crank v6. shouldn't have to change anything. I wouldn't be surprised if it was 3.9 rear. if the reason is sloppy shifting for wanting to swap.. they do need some help. There is a hurst by core shifters that is quite dramatic. a real short throw...very defined. I drive mine all day sometimes, city or not.. very easy going. Link to comment Share on other sites More sharing options...
Bootstrap Posted July 3, 2017 Author Share Posted July 3, 2017 The reason for the swap is that I'm eventually going to put an LS1 or 6.0L n the truck. Plus I'd prefer the auto with V8 when it comes to pickups. I've already got the interior stripped out and just thought I cld go ahead and change out column and instrument cluster for the auto trans while I had it all out. I know I need column, cluster, trans mount plate, and probably the drive shaft. I just didn't know if I needed anything else like a wire harness, somethin special for speedometer to wrk, etc. But if 5spd is best for 4.3 I'll leave it like it is. I just know truck is very weak. Plus it doesn't get but about 12-13mpg. Link to comment Share on other sites More sharing options...
dnl_paterson Posted July 4, 2017 Share Posted July 4, 2017 Sounds like a good project. If it was me, I would wait until I get everything together. Do you're research, get all the parts needed and then attack. Probably would be best to leave everything engine and drivetrain wise as is until. Sent from my N9560 using Tapatalk Link to comment Share on other sites More sharing options...
