rebranger Posted July 23, 2017 Share Posted July 23, 2017 I have a 2004 Z71, 5.3 V8, auto. All of a sudden the A/C clutch fuse began blowing. Disconnected connector on compressor, NO fuse blowing. Replaced A/C compressor, vacuumed & re gassed, A/C works fine for about 30 min, then blew another fuse. Removed plastic bottom shield (shroud) to get to wiring harness which was grommet-ed (attached) to around exterior of oil pan/block junction. Removed protective plastic wire shield. At the juncture of the wiring harness split on the passenger's side, the wires were very warm to the touch, no smoke, no burned wires, no shorts that I can find. It appears to be a bad connection in the circuit or a bad sensor somewhere. Anybody have any ideas of what/where to check next? PCM under hood had a 10 amp fuse, replaced it with a 20 amp, A/C ran a while (20 min, normal driving) then blew again!! Does the engine temperature sensor (drivers side towards front) have anything to do with this clutch control circuit? Quote Link to comment Share on other sites More sharing options...
silveradosid Posted July 25, 2017 Share Posted July 25, 2017 engine temp does not effect this, try cleaning condensor and make sure engine fan is operating properly Quote Link to comment Share on other sites More sharing options...
Bayerc Posted August 13, 2019 Share Posted August 13, 2019 Did you ever find a fix? I have the same issue. Quote Link to comment Share on other sites More sharing options...
sefiroxx Posted August 13, 2019 Share Posted August 13, 2019 Did you install a new/reman compressor?Did you reuse the coil? If so, the coil could be going. You can test the coil by checking resistance at the harness connector. Should be around 2-5. A short may not show until the circuit is heated up. Quote Link to comment Share on other sites More sharing options...
