Overhead Console Removal
Does anyone know how to remove the overhead console on the +15 Yukon? The one right in the middle with the map lights and everything. I want to look into the possibility of putting some switches up there and/or a voltage tap (But I'll need to step it down to +5)
Thanks
There's a small panel in the middle that snaps loose. Open the sun glass holder and you can get your finger on the edge, pull it straight down.
There is two small torx screws in there, I believe they are T15 size. Take them out. Then grab the whole console assembly working your way around the edges and pull the whole thing downward. Two clips in the front of the console towards the windshield hold the rest of the console up.
