- 0
Slight misfire at cruise
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 20 Members, 0 Anonymous, 1,929 Guests (See full list)
Question
2004BlueBurb
Hello all, I'm having an issue with my suburban, driving me nuts. My question is this, I have a 2004 Suburban 1500, 5.3L LM7 engine, 180k miles (my personal truck). Last Saturday I replaced the knock sensors due to a code set by bad bank 2 knock sensor, still had the baffles under the intake and sure enough, rear knock sensor hole has water and was rusty. Replaced both sensors with oe sensors with the harness. While I was there I replaced the valley cover gasket, cam sensor and oil pressure sensor. All went as planned, drove fine afterwards. The next day I was driving it the highway, noticed a slight misfire at cruise only, with a very slight load. Just a little bump here and there. Hooked up my scanner (Autel), #6 has 2-6 misfires randomly under light load cruise, which is 1500-2000 rpm. Swapped coils with #4, no change. Did the same with the plugs and wires, no change. Swapped injector with #2, no change. Has 140-150 psi compression. WOT has a lot of power, smooth, sometimes pings above 4500rpm, and idle is fine. Fuel trims at idle are bouncing up and down right around zero, wot they are about +4.
I'm at a loss of what to do next. In all the classes I've been to, whenever there is a mechanical problem, it's usually constant under load or at idle. I don't remember hearing about anything like this. Any advice would be very very much appreciated. Thank you guys n
Tyler
6 answers to this question
