x219c Posted September 19, 2017 Share Posted September 19, 2017 So, one of the biggest complaints I have about the way GM implemented CarPlay is the temperature. If you have Carolyn active, you can't see the outside temperature. If there was an easy way to have this info displayed on the DIC, that's what I'd prefer. But, I'm doubtful that'll happen. I do have a scangauge though! I searched and didn't see any threads sharing xcodes that work for our trucks. I am not near my truck at the moment, but I like the knock retard sensor reading. When I get back home next week, I'll post up the codes that worked for that one. Anyone have any cool ones to share? Ethanol content, outside air, etc? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted September 19, 2017 Share Posted September 19, 2017 These are available. Linear Logic sent me a data logger to find them. I can't find the codes she sent so I will resubmit this and see if I can fill in some blanks. Fuel Pressure Sensor Fuel Rail Pressure Sensor Calculated Engine Oil Temperature Torque Request Signal Traction Control Torque Request Signal Traction Control Torque Delivered Signal Torque Management Ignition Timing Retard Knock Retard Calcualted Air Flow Total Misfire Injector Duty Cycle Bank 1 Injector Duty Cycle Bank 2 Total Knock Retard Fuel Tank Rated Capacity Remaining Fuel In Tank Cooling Fan Motor Command TAC Motor Command Camshaft Postion Sensor Crankshaft Position Sensor Secondary Air Injection Pressure Sensor Variance Bank1 Secondary Air Injection Pressure Sensor Variance Bank2 Secondary Air Injection Pressure Bank 1 Secondary Air Injection Pressure Bank 2 Air Conditioner High Side Pressure Sensor Cooling Fan Speed Cooling Fan Command Exhuast Camnshaft Position Command Bank 1 Camshaft Postiion Command Exhaust Camshaft Position Bank 1 Intake Camshaft Position Bank 1 Desired Exhaust Camshaft Postion Bank 1 Intake Camshaft Position Variance Bank 1 Output Shaft Speed Sensor Transmission OSS Intake Manifold Pressure IAT Sensor 2 CPP Sensor – Percentage Transfer Case Output Shaft Speed Radiator Coolant Temperature Sensor Desired ECT Brake Pedal Posotion Sensor Ambient Humidity Intake Air Humidity Sensor Driver Requested Acel Torque Desired Fuel Rail Pressure Current Gear 1 Quote Link to comment Share on other sites More sharing options...
x219c Posted September 21, 2017 Author Share Posted September 21, 2017 These are available. Linear Logic sent me a data logger to find them. I can't find the codes she sent so I will resubmit this and see if I can fill in some blanks. Fuel Pressure Sensor Fuel Rail Pressure Sensor Calculated Engine Oil Temperature Torque Request Signal Traction Control Torque Request Signal Traction Control Torque Delivered Signal Torque Management Ignition Timing Retard Knock Retard Calcualted Air Flow Total Misfire Injector Duty Cycle Bank 1 Injector Duty Cycle Bank 2 Total Knock Retard Fuel Tank Rated Capacity Remaining Fuel In Tank Cooling Fan Motor Command TAC Motor Command Camshaft Postion Sensor Crankshaft Position Sensor Secondary Air Injection Pressure Sensor Variance Bank1 Secondary Air Injection Pressure Sensor Variance Bank2 Secondary Air Injection Pressure Bank 1 Secondary Air Injection Pressure Bank 2 Air Conditioner High Side Pressure Sensor Cooling Fan Speed Cooling Fan Command Exhuast Camnshaft Position Command Bank 1 Camshaft Postiion Command Exhaust Camshaft Position Bank 1 Intake Camshaft Position Bank 1 Desired Exhaust Camshaft Postion Bank 1 Intake Camshaft Position Variance Bank 1 Output Shaft Speed Sensor Transmission OSS Intake Manifold Pressure IAT Sensor 2 CPP Sensor – Percentage Transfer Case Output Shaft Speed Radiator Coolant Temperature Sensor Desired ECT Brake Pedal Posotion Sensor Ambient Humidity Intake Air Humidity Sensor Driver Requested Acel Torque Desired Fuel Rail Pressure Current Gear That’s quite the list. That would be awesome if you got that information! Thanks! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gone_fishing Posted September 22, 2017 Share Posted September 22, 2017 These are available. Linear Logic sent me a data logger to find them. I can't find the codes she sent so I will resubmit this and see if I can fill in some blanks. I too would be interested. The only x codes I have got working on my Scangauge are KR and engine oil temp. Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted October 3, 2017 Share Posted October 3, 2017 Here's a few I found in an old Email from Linear Logic. Having had any success getting new ones yet. Estimated Oil Temperature (Fahrenheit) TXD: 07E0221154(01) RXF: 046205110654 RXD: 3008 MTH: 00090005FFD8 NAM: EOT Torque Management Ignition Timing Retard (degrees) TXD: 07E022119C(01) RXF: 04620511069C RXD: 3008 MTH: 005A01000000 NAM: TIR Calculated Air Flow (grams/sec) TXD: 07E02211AC(01) RXF: 0462051106AC RXD: 3008 MTH: 000100800000 NAM: CAF Relative Humidity TXD: 07E0222301(01) RXF: 046205230601 RXD: 3008 MTH: 006400FF0000 NAM: HUM Current Gear TXD: 07E0223201(01) RXF: 046205320601 RXD: 3008 MTH: 000100010000 NAM: GER 1 Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted October 30, 2017 Share Posted October 30, 2017 Here's a few more pulled from my ECM. Engine Camshaft Position Sensor Pulses Engine Speed TXD: 07E0221420(01) RXF: 046205140620 RXD: 3010 MTH: 000100010000 NAM: User Defined Engine Cooling Fan Percent Commanded TXD: 07E0221641(01) RXF: 046205160641 RXD: 3008 MTH: 006401000000 NAM: User Defined Engine Cooling Fan Speed Actual TXD: 07E022162B(01) RXF: 04620516062B RXD: 3008 MTH: 001000010000 NAM: User Defined Engine Crankshaft Position Sensor Medium Resolution Reference Pulses Engine Speed TXD: 07E0221421(01) RXF: 046205140621 RXD: 3010 MTH: 000100010000 NAM: User Defined Engine Oil Pressure TXD: 07E0222345(01) RXF: 046205230645 RXD: 3008 MTH: 001400320000 NAM: User Defined Engine Fuel Alcohol Composition TXD: 07E0220052(01) RXF: 046205000652 RXD: 3008 MTH: 006401000000 NAM: User Defined Specific Humidity - Percent by Weight TXD: 07E0222303(01) RXF: 046205230603 RXD: 3008 MTH: 000500FF0000 NAM: User Defined 1 Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted November 3, 2017 Share Posted November 3, 2017 For those that don't have this feature on the dash: Cylinder Deactivation Commanded (On/Off) TXD: 07E0221133 RXF: 046225110633 RXD: 3001 MTH: 000100010000 NAME: CDC Unless there is something on the first list published you want I think I'm done here. Got all I need. Quote Link to comment Share on other sites More sharing options...
moab11 Posted November 3, 2017 Share Posted November 3, 2017 Any luck with Remaining Fuel In Tank? Seems like it would be nice to have sometimes. Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted November 4, 2017 Share Posted November 4, 2017 11 hours ago, moab11 said: Any luck with Remaining Fuel In Tank? Seems like it would be nice to have sometimes. Yes, but give me a day or so to retrieve it OR the instructions for that one are in your booklet. Quote Link to comment Share on other sites More sharing options...
moab11 Posted November 4, 2017 Share Posted November 4, 2017 ok, thank you. Just sent my scangauge away for the update to version 4, my old book didn't have the code, hopefully the new one will. Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted November 10, 2017 Share Posted November 10, 2017 Fuel Remaining TDX 23 RXF 800000000000 RDX 0000 MTH 000000000000 NAM REM Try that Moab11 Quote Link to comment Share on other sites More sharing options...
x219c Posted November 13, 2017 Author Share Posted November 13, 2017 Does anyone have the code for the outside air temp? When you have CarPlay going, you can't see it. I've seen them for intake temp, but not ambient temp like on the radio screen. Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted November 13, 2017 Share Posted November 13, 2017 24 minutes ago, x219c said: Does anyone have the code for the outside air temp? When you have CarPlay going, you can't see it. I've seen them for intake temp, but not ambient temp like on the radio screen. Have to dig it out of my scan tool. Patients please. 1 Quote Link to comment Share on other sites More sharing options...
x219c Posted November 13, 2017 Author Share Posted November 13, 2017 Have to dig it out of my scan tool. Patients please. Hey, thanks!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Grumpy Bear Posted November 13, 2017 Share Posted November 13, 2017 15 hours ago, x219c said: Hey, thanks! Sent from my iPhone using Tapatalk Bad news. It isn't on my list. That said you can contact Linear Logic and ask. Sometimes they don't publish all they know. Sorry. Quote Link to comment Share on other sites More sharing options...
