2014 exhaust fit 2013?
19 hours ago, 03blackz71 said:
Will an exhaust from a 2014 silverado 6.2l fit a 2013 silverado 6.2l without modifications? Reason I ask is I can get a lightly used magnaflow system
Absolutely. One thing I would recommend doing though is put new nuts back on the manifold studs with high temperature anti seize just in case you want to change something later. The factory nuts are garbage and will rust and strip so easy.
http://amzn.to/2zOeSLp - Nuts
http://amzn.to/2j2YvAM- High Temp Anti Seize
This is just the catback exhaust.   Not the manifolds.   I might go look at it tomorrow if he still has it.
Still a Y pipe right? Has to bolt to the manifold. Unless you're getting the 2500 type that slides in.
