Can anyone tell me where the XM "receiver" is located in the 2017 Silverado?  I need to get to the end of the XM antenna/plug to use it for my portable XM receiver.  I have seen past web posts "behind the glove box" (for previous years to 2017), but mine does not look anything like those misc videos.  I just need to know where it is... and how (easily) to get to it. I love my new truck! Thanks Very Much! DJ
Share this post
Link to post
Well Im not sure if the receiver is just part of the my-link system, but I can tell you the shark fin antenna on the roof is for your xm signal/on-star. Two connections come off that antenna and run just above the headliner down into the dash. The two connections above the headliner are accessed above the driver seat basically right above your head but closer to the windshield. Not sure which connection does what but that should get you started.
Share this post
Link to post
I appreciate your response. Yes, the "shark fin" is the XM antenna, but the end I am looking for is under the dash.  In "older" Silverados, they have you pop out the glove box and there is the receiver... maybe 4"x6"x1" where the other end of the antenna wire plugs in.  However, in my 2017 Silverado, behind the glovebox looks different and since I don't see anything familiar to the 4"x6"x1" box described above back there... that is my question.  Did they move the XM receiver somewhere else under the dash?
Share this post
Link to post
Maybe they moved it to behind the screen? I will try and see if I can dig something up for you.
Share this post
Link to post
I’d appreciate any guidance. My truck has less than 3k miles and I really don’t want to pull too much apart. I am hoping for “easy” access, but I guess we’ll see!
Share this post
Link to post
Also goes without saying... when we get an answer... pics would be very helpful. My need is to use my portable Onyx radio in my truck. Right now, I have it installed but with the magnetic antenna. Would really like to clean it up by using the shark fin.
Share this post
Link to post
I did this exact same thing a few months ago for my 2014 LTZ.  The connection for the Sirus antenna is behind the screen (top right). You can buy an adapter a extension cable and tie it right to your external unit.  Reception is way better than the magnetic antennas.
is a easy job just pick up some pry tools so you don’t damage the dash.
Share this post
Link to post
1 hour ago, djohnson01247 said:
Any guidance on starting to open the dash/screen?
There are tons of how tos on this site showing how to remove the screen.  Just search for “remove screen”. Just pop the trim off surrounding the screen and there are 4 hex bolts.  Remove them and slowly pry the screen towards you and it will pop out.
Super easy
Share this post
Link to post
I just stumbled onto this thread. Will the head unit pull from your receiver ? Or will you need to change channels / etc on the receiver itself?
I’m asking because I’m wondering if you could use an older receiver with a lifetime subscription in there somehow ?
Share this post
Link to post
I really appreciate all the help. My plan is to wait for a 5’ extension I ordered to come in. Then, I will tackle the job. I have an Onyx XM radio that I move from my daily driver (Volvo) and my Corvette. Now, I’ve added it to my 2017 Silverado... one subscription... 3 vehicles. Not bad!
Share this post
Link to post
You will still have to change the channels on the receiver etc.  this allows you to use the factory antenna with the aftermarket sirus head unit.    That’s exactly what I did (used an old unit with a lifetime subscription).  Works great.  I didn’t live the ui in the stock head unit anyway
Share this post
Link to post
Ah, thanks for the reply ! The lifetime sub was great in its day (still is). But with apps like pandora / Spotify / Apple Music/ etc I’m losing interest. I still have to investigate a little more though . If I can keep it clean I might still try it.
Share this post
Link to post
  • Popular Now
