Steve40th396 Posted December 5, 2017 Share Posted December 5, 2017 Trucks OEM remote start stopped working after check engine light came on. Codes are for EVAP items. Now the remote acknowledges lock doors, then immediately after hitting remote start button and holding it, lights come on, it makes a noise as if a cylinder moved, like doors cyphering, then it stops. But it wont start truck. Any idea what it may be? Link to comment Share on other sites More sharing options...
Gone Again Posted December 5, 2017 Share Posted December 5, 2017 Remote start is disabled with CEL on. Link to comment Share on other sites More sharing options...
Logan Lanfear Posted December 5, 2017 Share Posted December 5, 2017 17 minutes ago, Gone Again said: Remote start is disabled with CEL on. Yup, nothing wrong with the remote start. Link to comment Share on other sites More sharing options...
carnau Posted December 5, 2017 Share Posted December 5, 2017 1 hour ago, Steve40th396 said: Trucks OEM remote start stopped working after check engine light came on. Codes are for EVAP items. Now the remote acknowledges lock doors, then immediately after hitting remote start button and holding it, lights come on, it makes a noise as if a cylinder moved, like doors cyphering, then it stops. But it wont start truck. Any idea what it may be? Fix the Evap code and it will fix the remote start. As long as the SES light is on the remote start is inop. What codes are in the vehicle? Maybe I can help you fix it? Link to comment Share on other sites More sharing options...
Steve40th396 Posted December 5, 2017 Author Share Posted December 5, 2017 Thanx everyone. I replaced the vent valve and relocated the hose to the transmission and the pressure switch on the engine. COdes are still there. I have the pressure switch for the tank i am putting on this month, when I get a day off. Nice to know its not much more than the CEL causing this. Link to comment Share on other sites More sharing options...
carnau Posted December 6, 2017 Share Posted December 6, 2017 17 hours ago, Steve40th396 said: Thanx everyone. I replaced the vent valve and relocated the hose to the transmission and the pressure switch on the engine. COdes are still there. I have the pressure switch for the tank i am putting on this month, when I get a day off. Nice to know its not much more than the CEL causing this. NP glad we could help. Which pressure switch are you talking about btw? Link to comment Share on other sites More sharing options...
Steve40th396 Posted December 6, 2017 Author Share Posted December 6, 2017 7 hours ago, carnau said: NP glad we could help. Which pressure switch are you talking about btw? Tank Pressure Switch on top of fuel tank. Heard it can cause CEL too on evap system. Link to comment Share on other sites More sharing options...
carnau Posted December 6, 2017 Share Posted December 6, 2017 It could, But very uncommon. The vent valve you replaced, What did it look like? Did it look like this? http://amzn.to/2BEOhy2 Also, Do you have any type of scanner? If so we could do a quick test and see what's going on. A lot of times, people replace the fuel tank pressure sensor when the actual problem is the purge valve. Think about it. If the purge valve can't pull vacuum it will think the system has a leak. Purge Valve - http://amzn.to/2AYNYS8 Link to comment Share on other sites More sharing options...
Steve40th396 Posted December 7, 2017 Author Share Posted December 7, 2017 1 hour ago, carnau said: It could, But very uncommon. The vent valve you replaced, What did it look like? Did it look like this? http://amzn.to/2BEOhy2 Also, Do you have any type of scanner? If so we could do a quick test and see what's going on. A lot of times, people replace the fuel tank pressure sensor when the actual problem is the purge valve. Think about it. If the purge valve can't pull vacuum it will think the system has a leak. Purge Valve - http://amzn.to/2AYNYS8 I replaced both valves. It was scanned and I had this code. I am disconnected battery prior to replacing each one. CEL went out, then came back very quickly. I need to purchase my own scanner. Any recommendation for this truck, besides a Tech 2... Link to comment Share on other sites More sharing options...
carnau Posted December 7, 2017 Share Posted December 7, 2017 I don't even use my tech 2 anymore and I bought my own lol.I have a Bluetooth/Wifi scanner and I use Auto Doctor Pro. I carry it in my pocket all day long while I am at work and when I need to connect to a car I just pull it out and go. I can do just about everything with it besides programming. I can do all of the special functions tests, see all of the graphs, command the inputs and outputs. It works great. I was skeptical at first. But now all of the mechanics have one just because of how easy it is to use and you don't have to carry that big tech 2 and the candi module around with you. Also you can scan codes all the way up to 18 now. http://amzn.to/2ktqcXR is the bluetooth OBD2 I use. Link to comment Share on other sites More sharing options...
Steve40th396 Posted December 12, 2017 Author Share Posted December 12, 2017 On 12/6/2017 at 9:48 PM, carnau said: I don't even use my tech 2 anymore and I bought my own lol.I have a Bluetooth/Wifi scanner and I use Auto Doctor Pro. I carry it in my pocket all day long while I am at work and when I need to connect to a car I just pull it out and go. I can do just about everything with it besides programming. I can do all of the special functions tests, see all of the graphs, command the inputs and outputs. It works great. I was skeptical at first. But now all of the mechanics have one just because of how easy it is to use and you don't have to carry that big tech 2 and the candi module around with you. Also you can scan codes all the way up to 18 now. http://amzn.to/2ktqcXR is the bluetooth OBD2 I use. Got the tool. Works great. Thnx Link to comment Share on other sites More sharing options...
bgbdwlf2500 Posted December 12, 2017 Share Posted December 12, 2017 On 12/6/2017 at 9:48 PM, carnau said: I don't even use my tech 2 anymore and I bought my own lol.I have a Bluetooth/Wifi scanner and I use Auto Doctor Pro. I carry it in my pocket all day long while I am at work and when I need to connect to a car I just pull it out and go. I can do just about everything with it besides programming. I can do all of the special functions tests, see all of the graphs, command the inputs and outputs. It works great. I was skeptical at first. But now all of the mechanics have one just because of how easy it is to use and you don't have to carry that big tech 2 and the candi module around with you. Also you can scan codes all the way up to 18 now. http://amzn.to/2ktqcXR is the bluetooth OBD2 I use. amazon doesn't have any in stock and sounds like they may not get them anymore. any other suggestions? Link to comment Share on other sites More sharing options...
carnau Posted December 12, 2017 Share Posted December 12, 2017 http://amzn.to/2BbxyGf Same exact one just a different company name on it. Link to comment Share on other sites More sharing options...
GhostWriter Posted December 13, 2017 Share Posted December 13, 2017 On 12/6/2017 at 8:48 PM, carnau said: I don't even use my tech 2 anymore and I bought my own lol.I have a Bluetooth/Wifi scanner and I use Auto Doctor Pro. I carry it in my pocket all day long while I am at work and when I need to connect to a car I just pull it out and go. I can do just about everything with it besides programming. I can do all of the special functions tests, see all of the graphs, command the inputs and outputs. It works great. I was skeptical at first. But now all of the mechanics have one just because of how easy it is to use and you don't have to carry that big tech 2 and the candi module around with you. Also you can scan codes all the way up to 18 now. http://amzn.to/2ktqcXR is the bluetooth OBD2 I use. Would this be able to perform the routine that exercises the ABS solenoids, if you believe you have air trapped in the module? Thanks. Link to comment Share on other sites More sharing options...
carnau Posted December 14, 2017 Share Posted December 14, 2017 3 hours ago, GhostWriter said: Would this be able to perform the routine that exercises the ABS solenoids, if you believe you have air trapped in the module? Thanks. I am going to check right now. Link to comment Share on other sites More sharing options...
