- 0
Tail Light Issues 2011 2500HD Chevy
Similar Content
- 1 reply
- 1,551 views
- 1 reply
- 932 views
Silverado LTZ/High Country LED Tail Lights $440 w/ OEM Harnesses 1 2
By youn1033,
- led
- tail light
- (and 4 more)
- 29 replies
- 11,991 views
- 41 replies
- 61,079 views
- 8 replies
- 101,784 views
Recently Browsing 0 members
245.8k
Total Topics2.6m
Who's Online 19 Members, 0 Anonymous, 1,471 Guests (See full list)
Question
jbrunsvig
Having issues with the right rear tail light. The wiring harness had a bad wire in it so instead of fixing it i replaced it, when i did that the lights on that side lit up like the brakes were on and the lights on the drivers side lit up normal when i started the truck. When I turn on the left blinker it works fine, when i turn on the right blinker the lights are normally bright and the left lights come on very dim but blink with the right, they also blink like there is a bulb out (very fast). I also replaced the block where all the harnesses meet bc it looked corroded and it was cheap.
I tested the power coming from the main harness that comes into the block and discovered that the fast blinking was coming from that direction.
My question is, would that make a difference if the tail lights are not hooked up, or is there a blinker relay that I can't find?
Thank you,
3 answers to this question
