- 0
2009 6.0L AFM delete
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 28 Members, 1 Anonymous, 2,004 Guests (See full list)
Question
Tunnelgas
Good afternoon. First post to thread. Thanks in advance for any assistance and guidance.
A little background...my apologies in advance if I do not explain everything properly as I am not a mechanic...rather a tinkerer with what I would like to think is some common sense and understanding.
I have a 2009 Suburban 1500LTZ 4x4 with a 6.0L. It has 160,000 miles give or take and has been an excellent vehicle for our family. At around 150,000 miles it dropped a lifter. At that time, I pulled it down and replaced just the one lifter, put it back together and it ran fine for about 10,000 miles until it recently lost another lifter.
I spoke to an engine shop around town and they suggested that I should have gone ahead and replaced all of the lifters and the cam when I pulled it down the first time and that I should do that now. They also suggested I do away with the AFM. I did a little research and found that some had done this with good success. I reached back out to the engine shop and they indicated that they sold a kit for this. The kit included new replacement valley plates, new LS7 solid lifters, etc. I confirmed with them that a stock cam could be installed and I ordered that directly from Chevy. I also ordered a new oil pump.
I methodically went through everything, buttoned the engine back up and started the engine. It had a knock in it but it had not been tuned yet so I didn’t think much of it. I trailered the vehicle to that engine shop to have the AFM tuned out of the ECM. They commented there that they thought the knock was a piston issue. I had a hard time believing this since it was running perfectly prior to loosing the lifter, but the knock is bad! I have checked compression and it is good in all cylinders. I made up a test plate to check oil pressure coming out of the oil pan and put another gauge in line at the sending unit. I am getting a fairly steady oil pressure of 30lbs at the bottom (seems a little low) but it fluctuates between only 7-12lbs on the other gauge. I pulled the engine back down and checked the lifters and cam...they seem fine. I checked the bottom end when I pulled the oil pan and everything seems fine there as well.
For the life of me I cannot determine the cause or source of the knock. It does not get better when it is warmed up. I have driven it a little just to see if anything else presents itself as a problem. The engine is not missing at all, accelerates fine, etc.
Any ideas on where I should look or what I should do? In hind sight, I guess I should have just replaced the lifters and cam with stock parts but from what I was reading the AFM delete was pretty straight forward and when the engine shop told me they sold a kit I thought it would be a good time to simplify things. I am now wishing I hadn’t but remain hopeful that there is some experience that I lack that can help me get things back in line.
Thanks,
Steve
6 answers to this question
