Owens539 Posted February 23, 2018 Share Posted February 23, 2018 so I just bought a 2018 custom . I looked at the hood latch and it already has the wiring harness hooked up to it. It has the key fob with the lock and unlock buttons. no rpo codes on 2018 models in glove box. i scanned the qrcode in the door and it came up with like 40 codes that are hit and miss to figure out what's what. the "kit " comes with a hood latch and two fobs for $299 and my dealer said it's $150 to "install" any insight here what I should do? Link to comment Share on other sites More sharing options...
Back in a Bowtie Posted February 23, 2018 Share Posted February 23, 2018 $450 for factory remote start isn't bad IMHO. Do you know if it will give you use of the app as well? Link to comment Share on other sites More sharing options...
JeremyW426 Posted February 23, 2018 Share Posted February 23, 2018 There are older posts on this topic. Once the GM remote start system is installed, you can contact onstar, speak to their Tier 2 Tech Support and they'll have to put in a ticket to have your vin updated in their system to reflect as though your vehicle came with BTV (rpo code for remote start) and then the app will allow for remote start right from your phone. Pretty nice, takes about a week but worth it. Link to comment Share on other sites More sharing options...
Owens539 Posted February 23, 2018 Author Share Posted February 23, 2018 Can I do the programming myself? I cringe thinking I'm paying the dealer $150 to make a phone call.. on top of that I just bought the "kit" for $200 when all I need is the pin number... I have access to a ob2 plug with the laptop and also.. maybe I can just call gm ? Give them the pin? Link to comment Share on other sites More sharing options...
JeremyW426 Posted February 23, 2018 Share Posted February 23, 2018 I'm 99% sure that it cannot be done without a GM Tech 2 Scanner and will absolutely require your dealer to program it. Link to comment Share on other sites More sharing options...
Owens539 Posted February 23, 2018 Author Share Posted February 23, 2018 27 minutes ago, JeremyW426 said: I'm 99% sure that it cannot be done without a GM Tech 2 Scanner and will absolutely require your dealer to program it. Link to comment Share on other sites More sharing options...
JeremyW426 Posted February 23, 2018 Share Posted February 23, 2018 Just now, Owens539 said: Link to comment Share on other sites More sharing options...
KillerOfMillers Posted February 23, 2018 Share Posted February 23, 2018 double post... Link to comment Share on other sites More sharing options...
KillerOfMillers Posted February 23, 2018 Share Posted February 23, 2018 source.mp4 Link to comment Share on other sites More sharing options...
2016 Sierra Owner Posted February 23, 2018 Share Posted February 23, 2018 3 hours ago, Owens539 said: Can I do the programming myself? I cringe thinking I'm paying the dealer $150 to make a phone call.. on top of that I just bought the "kit" for $200 when all I need is the pin number... I have access to a ob2 plug with the laptop and also.. maybe I can just call gm ? Give them the pin? No you can't it has to be done at the dealer unfortunately. In the kit there is a code that the tech uses to call GM and get authorization to reprogram the truck for RS. Link to comment Share on other sites More sharing options...
newdude Posted February 24, 2018 Share Posted February 24, 2018 On 2/23/2018 at 8:52 AM, Owens539 said: so I just bought a 2018 custom . I looked at the hood latch and it already has the wiring harness hooked up to it. It has the key fob with the lock and unlock buttons. no rpo codes on 2018 models in glove box. i scanned the qrcode in the door and it came up with like 40 codes that are hit and miss to figure out what's what. the "kit " comes with a hood latch and two fobs for $299 and my dealer said it's $150 to "install" any insight here what I should do? Get the instructions, install it yourself and have the dealer program it using the authorization code. Or, have the dealer do it all. Link to comment Share on other sites More sharing options...
lawnboy-5247 Posted February 24, 2018 Share Posted February 24, 2018 If your dealer will install for $150 I would have them do it. I bought the kit and installed it myself and no dealer in my area would program it for less than $100.Sent from my LGLS991 using Tapatalk Link to comment Share on other sites More sharing options...
aczr2k Posted February 28, 2018 Share Posted February 28, 2018 Skip the factory one and go aftermarket, Compustar, astrostart. The ongoing joke with my buddies that all have new GM trucks is hold your hand on the hood autostarts because that is how far the range is. Link to comment Share on other sites More sharing options...
