Cylinder #1 Misfire
I have 2012 GMC Sierra 5.3.  Had to have new engine installed under warranty about 1.5 years ago.   2 days ago it started running rough at idle and eventually threw the cylinder 1 misfire code.  I swapped plugs 1-3 and misfire went to cylinder 3 with the plug.  The plug from cylinder 1 was fouled and oil'd up.  After replacing the plug last night.  The rough idle and code has stayed away.  I also cleared all codes with a scan tool.
My question is... am I looking ahead for something bad.  What would cause all that oil on the plug.   I drove it for about 2 days with the misfire.  The replacement engine only has about 25k on it.  Plug on left is from #3  right was #1.
I actually made a video about this! So here you go. In the video it is on Cylinder number 7. But 1 and 7 are the two that foul out.
Here are the parts you need.
Valve cover - http://amzn.to/2C5MIhd
41-110 Spark Plug - http://amzn.to/2E8oD71
Make sure you like and subscribe to my youtube channel while you are at it.
  • 1 year later...
