Wheel Bearing Replacement. Learn how to diagnose and replace the wheel bearing hub assembly on almost any truck or car. This is a 2004 Chevy Silverado, GMC Sierra but the process will be very similar for replacing any wheel bearing hub assembly with an axle running through it. I was able to purchase a new hub assembly from AutoZone for $120. Duralast Wheel Bearing/Hub Assembly-Frnt. We will provide a review of the wheel hub assembly after testing it for some time before recommending you to purchase it. Other wheel hub assembly companies: Moog, NAPA, Driveworks, Timken. Here is the Wheel Hub Assembly that I used: https://www.autozone.com/suspension-s... Similar Wheel hub assembly products available on RockAuto: https://www.rockauto.com/en/catalog/c...
Required Tools
• 15mm Wrench
• 18mm Socket
• 22mm Socket
• 35mm Socket
• Lug Wrench
• A Piece of Pipe (for leverage)
• Ratchet
• Torque Wrench
• Hammer
• Chisel
• Jack Stands
Edited by The.Sundae.Drive
Share this post
Link to post
