- 0
1996 C1500 5.7l P0300 code
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 25 Members, 1 Anonymous, 1,838 Guests (See full list)
Question
jmach96
I have a p0300 code above 2000 RPM's with all driving conditions including towing. I encountered the problem 2 years ago during California smog test. I have searched DIY "fixes" and have diagnosed problems, completed fixes and still have had problems. The truck, with 149000 miles runs well and gets 13.4 mpg city and 15.6 highway. it has been taken to two independent shops, with numerous repairs, and no fix, until finally, it is with a Chevrolet dealer in Santa Ana, California. My biannual smog test is this July and I need some help in understanding this problem and process. Last smog test I cleared the code and drove the vehicle ~30 miles below 2000rpm and talked with smog tech that kept truck at 1900rpm on dyno for test that met the + or - 100 rpm California requirement. As a Note compression tests completed at least 2x a year since 7-16 with less than 3lbs difference from first to last with base results of:
CYL#
1=180 3=170 5=168 7=170
2=180 4=170 6=170 8=175
The DIY fixes performed 7-16 thru 9-17:
1) Spark balance and spark gap test - replaced cap,rotor,wires,plugs,coil utilizing dialectric grease - with ACDelco brand
2) All 4 O2 sensors based on exhaust analysis per smog tech i.e. higher than average NOx and CO2 - with ACDelco brand from local dealer
3) MAF sensor based on trim codes for injectors which showed lean trim above 1600rpm - with ACDelco brand
4) Fuel pump replacement due to low pressure, less than 55lbs at idle (~53lbs) - with ACDelco brand from local dealer
5) All Engine compartment harness connectors removed, inspected, cleaned with wd40 electrical contact cleaner and all relays tested with ohm meter, cleaned and re-secured
Independent shop repairs 11-16 thru 7-17:
1) Lower/upper intake gasket, spider injectors and fuel pressure regulator due to failed leak down test and wet spark plug #5 cylinder
2) Distributor, spark exciter and spark knock sensor as a "could only be the problem left" explanation by shop
3) Throttle position sensor and egr valve and egr engine temp sensor as a "could only be the problem left" explanation by shop
Chevrolet Dealer 03-18 to present: Note: truck developed an engine knock (diagnosed as piston, piston pin or rod bearing failure), excessive rear main oil leak and check engine light "on" at 2000rpm - customer stated concerns on original service estimat/order
1) New crate long block engine with harmonic balancer and tins (12530283), new spider injectors, crankshaft timing sensor, motor mounts, water pump and thermostat, cap, rotor, wires and plugs.
Good news the knock and oil leak are gone! Bad news check engine light on above 2000 rpm. Have taken truck back twice to dealer, first repair was timing adjust, with no fix, now I'm told problem may not be repairable, my option is for Chevrolet Performance to look at truck, diagnose at an expense to me, credited towards cost of any repairs I approve.
What are your thoughts: impression, advice, process, guidance?
3 answers to this question
