Why chevy didnt bolt the air box down is beyond me, and I will never profess to understand why car makers do what they do... so.....
While fooling around with the idea of bolting this box down to the vehicle.. I pulled the steel plate the sits below the air box. The only apparent purpose of this plate was to hold the rubber mounting sleeves that the airbox sits in. Also, below this plate is a world of fresh cold air straight from the ground. Protected from engine heat on one side and road debris by the fender well... (insert lightbulb over head here!).
I cut a approx 5x7" piece from the bottom of the air box and siliconed a screen over the hole to keep large debris out, though I dont see it picking up too much road debris this high, you never know.
I then used the stock water drain hole (which conveniently lined up the a stock mounting hole for the plate... drilled another hole on the opposite side of the box and bolted her down...
Now no more rattle and more air flow..
The butt dyno says we have success. Noticeably more pull and upper rpm band power. I will have to get her on the dyno to see if it all is for real...
We did this on the MKIV Audi/VW's in my last car club and the modified stock box actually outperformed ALL cold air intakes when coupled with a high flow air filter..
We will see if the same is true for GM I guess...
Any opinions? Negative/Positive??
Thanks,
Rodric
Edited by 02Tahoe2Quick, 07 November 2003 - 04:34 PM.
