Largest tires that will fit a Trailblazer 16s
This topic has been archived. This means that you cannot reply to this topic.
11 replies to this topic
#1 Fishhunter911
Fishhunter911
  • Newbie
  • 64 posts
Posted 31 March 2004 - 08:01 AM
Anybody know what the largest tire is that will fit the trailblazer with 16 inch wheels??? I want something a little more aggressive
#2 Ranger354
Ranger354
  • Member
  • 85 posts
Posted 13 April 2004 - 10:19 AM
A buddy of mine put some larger tires on his wife's TB and it really filled in the wheel wells. Looks nice. I think they are the next larger size. He had to do a little grinding on the pivit joint above the inside of the tire. Only about a credit card width though. He was looking for some spacers to offset the factory wheels, but couldn't find any. I am thinking about doing the same thing when these tires wear out.
Ranger
#3 03TRAILEXT
03TRAILEXT
  • Member
  • 241 posts
  • Gender:Male
Posted 14 April 2004 - 08:17 AM
looks like 245 70 16 amybe 255, just asked gary at tire rack.
2011 Black Traverse LTZ AWD
#4 Ranger354
Ranger354
  • Member
  • 85 posts
Posted 14 April 2004 - 10:42 AM
My 2004 has 17" wheels on it and trying to find tires are alot harder then 16". My buddy that just did the grinding traded in his 2002 with 16's for a 2004 with 17's. I had told him to swap the 17s for the 16s so he would have a better tire selection. But he didn't
#5 TBSDMD
TBSDMD
  • Newbie
  • 36 posts
Posted 18 May 2004 - 09:53 PM
Search chevy wheel spacers on ebay, they have them for the trailblazer. 1.5 in spacers for 90.00 a pair
#6 n516gkj
n516gkj
  • Member
  • 12 posts
  • Gender:Male
Posted 02 June 2004 - 07:01 AM
i replaced my 245x70 with 255x65.. it looks a little better but this change was very minor.... tire is only 10mm wider and rolling diameter stayed the same.....
2007 Tahoe 4x4, 5.3L FlexFuel
Dark Blue Metallic, Ebony Interior
LT3 Package, Sunroof, Rear DVD
Polished 20"s, 3.73 gears, G80 Diff.
Edge Evolution, Valentine1 Radar
#7 03TRAILEXT
03TRAILEXT
  • Member
  • 241 posts
  • Gender:Male
Posted 03 June 2004 - 04:39 PM
Not a good idea, makes the lugs weaker
#8 TBSDMD
TBSDMD
  • Newbie
  • 36 posts
Posted 06 June 2004 - 09:51 AM
doesn't make the lugs weaker. They are not any different than putting on offset wheels
#9 03TRAILEXT
03TRAILEXT
  • Member
  • 241 posts
  • Gender:Male
Posted 22 June 2004 - 02:06 PM
ok :banghead:
#10 Roger-Ohio
Roger-Ohio
  • Newbie
  • 1 posts
Posted 15 July 2004 - 11:08 AM
RE Wheel spacers.
1. If they are just spacers then your lug nuts may not completely engage the studs.
:bs:
2. If the spacers are bolted on to the hub first and are aluminum then think about the fact that normal lug studs are grade 8 in steel and now you are using grade ? in aluminum. :D
3. No matter what you are now loading the ball joint and suspension in a manner they were not designed for. So will need to keep an eye on these parts over the long run. Yes different offset wheels do the same loading thing. :lol:
Just remember that you are modifying the vehicle and now YOU are responsible for result.
#11 TBSDMD
TBSDMD
  • Newbie
  • 36 posts
Posted 22 July 2004 - 09:25 PM
and your point is...... :banghead: You drive it off the lot and it is prettty much your problem. Yes some stuff will get covered by warranty. All I mostly was getting at with the spacers is that if you look at your suspension in the front you would see that larger tires would scrape on the upper section of the suspension. The spacers would bring the tire out so as to avoid the scraping which then allows bigger tires to be run. I do however think that a 265 or a 31in. will be as big as you can go without them rubbing when turning
Edited by TBSDMD, 22 July 2004 - 09:35 PM.
#12 Dragonhead08
Dragonhead08
  • Newbie
  • 9 posts
Posted 25 October 2004 - 01:07 PM
245/75/16 bf goodrich AT no rubbing even under full compression. I've seen guys put 285/75/16.'s with a 2" lift. He had to trim a little in the wheel well though. If you dont want ot deal with the trimming 265/75/16 with a 2" lift will work just fine.
Advertise Here
