* * - - - 1 votes
AC Delco plugs
This topic has been archived. This means that you cannot reply to this topic.
39 replies to this topic
Poll: Which plugs do you run?
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Vote Guests cannot vote
#16 timh975
timh975
  • Member
  • 23 posts
Posted 02 May 2006 - 01:10 AM
2002 2500hd,6.0L. i changed to the ac-delco #41-983, at .040" gap. i am seeing a 2 mpg drop in my milage. any body else? this plug is at .040" gap, when the oem plugs were at .060" gap.
thanks.
<{POST_SNAPBACK}>
Hey REBOP, I noticed a slight drop in MPG's also. I recently replaced the plugs in my 6.0 with the iridium plugs. Even though the sticker under the hood says .060" gap, the dealer told me to leave the new plugs gapped at .040", it will run fine and will also run cooler. My truck ran just fine with original plugs, now I'm wondering if I should've just left them alone.
My GMC truck pics on Cardomain.com
2000 GMC Sierra 2500
Ext. Cab Short Bed SLE
Flowmaster Exhaust
HD Roof Marker Lamps
265/75R16 Michelin LTX M/S Load Range E
7 1/2' Western Pro Plow
#17 REBOP
REBOP
  • Member
  • 28 posts
Posted 02 May 2006 - 07:55 AM
thanks.
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
i went back to the autolite double platium at .060" gap. my milage is back to normal. check this out :
http://www.sparkplugs.com/default.asp
thx - rebop.
#18 Haulin' 8.1
Haulin' 8.1
  • Member
  • 670 posts
  • Gender:Male
Posted 10 June 2006 - 07:18 AM
I didn't just pull this out of my !@$. I've been tuning engines for geeze longer than I care to remember and most who know me think I'm one of the best.
The wider your plug gap is the leaner the fuel mixture can be.  I run my Champion Double platinum plugs wider than stock for better milage.  Todays ignitions will jump the gaps way beyond reason, I know I do peoples tune ups, so an extra 0.005 isn't a problem if you change plugs every 50K but it sure helps the mileage.  Don't try it with a supercharger or NO2 though.
Vernon
<{POST_SNAPBACK}>
2001 Siverado HD 2500 SBCC in Black
GM Vortec 8100, Allison, 3.73, 4X4
Mods: Goodmark SS cowl hood, Ranch Hand bumpers, black toolbox, custom bed cover, full tint, Volant with home made ram air, BBK 80mm TB, Granetelli MAF, Marine Injectors, Hypertech, Champion RS12YC plugs, Magnaflow 3" dual in X-path dual out muffler and tail pipes, Fuzion XTi 265's, Velvet Rides, Pioneer 10" subs, amps, you know the usual stuff.
Coming soon: 4.56 gears, Autorotor supercharger by Whipple with Duramax intercooler, and GM HP3 cylinder heads.
If you've modded your 8.1's timing and run hard try Champion RS12YC plugs gapped at 0.055". Less knock, more power. Yes you have to change them more often (25K), but this is a performance mod. Besides they're cheap and easy to do.
Yea though I drive the the valley of the shadow of Diesel,
I will fear no turbo;
For your horsepower art with me;
Your bore and stroke, they comfort me.
#19 Steady Eddie
Steady Eddie
  • Member
  • 60 posts
Posted 10 June 2006 - 11:52 AM
:chevy:
Didn't Delphi file a Chapter 11? Aren't Denso Iridiums now
OEM installed in all 8.1s? Isn't there a TSB on plug gaps?
(I'm thinking of one for the Corvette and others). Are the
AC-Delco Iridiums made by NGK?
Steady Eddie :)
Edited by Steady Eddie, 26 June 2006 - 11:02 PM.
Steady Eddie
Moderator:
The_P12_Chassis_Group
Yahoo! Groups
Owner:
1999 Newmar 3357
Motorcoach
1998 P12 MD Chevy Chassis
26,000# CGVW Rating
454 L-21 w/Allison
#20 duramaxHD
duramaxHD
  • Member
  • 186 posts
Posted 12 July 2006 - 06:12 PM
I dunno, whichever ones my truck came with...
:rant:
2005 silverado cc/sb 4x4 LT
dmax/ally
not the original engine, and a buncha other stuff too.
#21 Haulin' 8.1
Haulin' 8.1
  • Member
  • 670 posts
  • Gender:Male
Posted 12 July 2006 - 10:23 PM
Shirley, you can't be serious.
Vernon
#22 kraig
kraig
  • Newbie
  • 8 posts
Posted 27 November 2006 - 09:40 PM
My 01 6.0 has 93,000 and I changed my plugs. They were the factory parts, and they were worn...BAD. Five gaps were huge, .80-.85. No foolin. Put the A/C Delco plugs back in, which have a NGK number also, just like the ones that came out. The computer and the catalog said do not change the gap which is pre set to .40 but yes the underhood sticker says .60...go finger. Seems like it does not idle as smooth, it does have a little more poop and gets about 15 more miles out of the first half of the fuel tank on the highway. I get on it too much to notice a difference in town. Jus my .02. :rolleyes:
#23 MS3DALE
MS3DALE
    Senior Enthusiast
  • Moderator
  • 15,071 posts
  • Name:Rich
  • Gender:Male
  • Drives:'07 Silverado Z71 '11 Camaro SS '02 Saturn SC2
Posted 27 November 2006 - 11:12 PM
Heres the bulletin on the spark plug replacement and gap....
Document ID# 1396703
Subject: Information on New Spark Plugs and Gapping #03-06-04-060 - (10/24/2003)
Models: 2004 Buick Ranier
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
2004 Cadillac CTS-V
1997-2004 Chevrolet Corvette
1998-2002 Chevrolet Camaro
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche
2003-2004 Chevrolet Express, TrailBlazer
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon XL
2001-2004 GMC Yukon Denali, Yukon XL Denali
2002-2004 GMC Sierra Denali
2003-2004 GMC Envoy XL
1998-2002 Pontiac Firebird
2004 Pontiac GTO
2003-2004 Hummer H2
with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Copyright General Motors Corporation. All Rights Reserved.
2015 Silverado Crew-Cab LTZ "Midnight Edition" - 6.2 - 8 spd. - CORSA exhaust - AIRRAID intake tube - 1.5" leveling - HUSKY floor liners - EXTANG full-tilt tonneau - BEDRUG - more to come!!
2011 CAMARO 2SS/RS - LS3/M6 - Inferno Orange Met. - HURST short-throw - Roto-Fab CAI - Kook's LTs - CORSA exhaust - Black Bear tuned (playtoy!)
2012 CRUZE 1LT - Blue Topaz Met. - RS pkg.- Convenience pkg. (work car!)
#24 Black02Silverado
Black02Silverado
    Senior Enthusiast
  • Supporting Vendor
  • 3,730 posts
  • Gender:Male
  • Drives:2002 Silverado
Posted 22 February 2007 - 12:48 PM
Interesting. It was suggested to me by the individual that does my oil analysis to do this exact thing, get the Iridiums and gap them at 0.040. He mainly instructed this to help improve my economy.
Black 02 Silverado Z71, 5.3L Amsoil Fluids Black Bear Tuned with AutoCal
Black 2013 Camaro 2SS/RS M6
Tungsten Grey Metallic 2014 Cruze Diesel
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
9952b567-a2a8-480a-b054-4c7d5b2dd856_zps
#25 Billdog350
Billdog350
  • Member
  • 112 posts
Posted 22 February 2007 - 02:59 PM
I pulled a set of what looked like origional DELCO plugs from my truck after 130k mi. Some of the platinum tips had worn off! The plugs had NGK AND DELCO written on them (I can take pics if people don't believe me). They were in my 2003 6.0l Lq4.
I threw some iridiums in there and it runs great.
#26 dco111
dco111
  • Member
  • 16 posts
Posted 19 March 2007 - 11:52 AM
Haulin8.1 you refer to running champion plug and gapping them to 40 and changing them every 25,000 miles. Will this work for pulling, I have a 03 3500 with the 8.1 and all I do is pull with it. Every body talks about making them run faster but few talk about pulling. Thank you.
#27 Haulin' 8.1
Haulin' 8.1
  • Member
  • 670 posts
  • Gender:Male
Posted 29 May 2007 - 07:25 PM
Hey I don't read this post a lot. But yeah they'll work fine in any 8.1 that's used for increased performance. They're basically a normal 8.1 plug that's one step colder than stock. The copper core retains less heat than the exotics so it's good for long period WOT detonation resistance. The smaller gap is for reduced WOT misfiring. Even though the copper is a good cool electrod it wears away faster than the other metals so about 25K miles would be my limit. The good thing is that these ignition coils are so strong and the smaller gap take a while to wear past limits so you'll probably not have any issues at 25K anyways.
Vernon
#28 Waterfowlhunter
Waterfowlhunter
  • Newbie
  • 1 posts
Posted 28 July 2007 - 02:00 PM
I had the same white carbon buildup on my factory plugs after 40,000 miles and was told by the dealer that this is due to running 87 octane gasoline. I have now been running 89 and I can tell a difference. This 8.1L engine was rebuilt at 20,000 due to the oil pump bypass spring failing and killing the engine. They replaced only one plug at that time and it was an ac delco but the remaining 7 were Denso 5071 double Platinum. All gapped at .060. I replaced them all with Denso Iridium 5325 at .060 and it ran real bad so I dropped them to .050 and it ran great again but I also replaced 2 wires at that time with OEM wires. I have since had to replace a failed camshaft position sensor. Should I go back and gap the plugs to .060 again or leave them at .050?
Is there a performance plug wire for these engines?
#29 Haulin' 8.1
Haulin' 8.1
  • Member
  • 670 posts
  • Gender:Male
Posted 31 July 2007 - 06:35 AM
Leave them at 0.50", it works doesn't it? Opening it up will only slightly improve part throttle emmissions at a great reduction in heavy throttle power. There are wires that are built stronger and have thicker insulation but any gains in power will be so small they aren't worth the expence. The OEM and built to OEM specs wire sets have a solid core so conductivity is very good and long lasting. Nobody uses carbon core wires in this day and age yet many think wires are still a first upgrade.
Vernon
#30 07vmaxslt
07vmaxslt
  • Member
  • 71 posts
  • Gender:Male
Posted 29 August 2007 - 09:18 AM
Rebop,
what does the sticker under the hood call for plug gap? Use that. (my guess is they should be .060) Remember, you have to gap ALL plugs, especially when new.
What if the spark plug box tells you not to? :cheers:
NBS - Sierra crew cab SLT 4x4- Vmax 6.0 - 4.10 gears - NHT package (rear disk YES!) - Sunroof- Volant CIA system - AVS bug shield. (GM bug shield coming) - back to 50 series Flow master. Corsa to loud on inside - Wait4metune - No more AFM crap - Nerf tubbed step bars - Yellow top optima battery - Alpine DVD player up front 10.2 screen in the back, 2 = 10 inch Excelon subs & type X components from Alpine in all doors; JL v2 amps - Front tint - GM bed rails - More mods to come!
