When GM Releases a TSB...
This topic has been archived. This means that you cannot reply to this topic.
4 replies to this topic
#1 TxDoc
TxDoc
    Senior Enthusiast
  • Member
  • 1,096 posts
  • Gender:Male
  • Drives:Favorite is 2003 QuadraSteer
Posted 03 February 2002 - 12:55 PM
Is there any responsibility with the dealer or with GMC or Chevrolet to contact truck owners and inform them of a TSB?  I hear people inquiring about them and it seems like if you are not "in the know" on finding them on the net, then you are lost.
Bulletins for 1997 GMC Truck K 1500 P/U 4WD V8-350 5.7L VIN R SFI
Safety Recalls
    TSB Number   Issue Date  TSB Title 98044          AUG 98       Fuel Tank - May Contact Body Sill
97008A         JUN 97       Seat Recliner Hinge Pinch Point
97006          FEB 97       Clutch Pedal Separation From Pivot Bracket
Emissions Recalls
    TSB Number   Issue Date  TSB Title 97024          AUG 97       Incorrect Linear Exhaust Gas Recirculation Valve Used
Service Bulletins
    TSB Number   Issue Date  TSB Title 01-07-30-023   JUN 01       A/T - Harsh 1st to 2nd Gear Upshift/DTC P1870 Set
01-08-44-006A  JUN 01       Audio System - Clearing `CLN' Message From Display
01-00-89-010   JUN 01       Diagnostic Worksheet - Usage
01-09-40-002   JUN 01       Seat Belt System - Collision Replacement Guidelines
01-00-89-011   JUN 01       Vehicle - Technical Assistance Form
99-01-39-004A  MAY 01       A/C - Odor Emission in Hot Weather
01-01-38-006   MAY 01       A/C System - Flushing Procedures
01-07-30-002B  MAY 01       Ignition Switch - MIL ON/Inoperative Instruments
01-00-89-009   MAY 01       Key/Key Number/Security Chip - Replacement
01-07-30-021   MAY 01       Park/Neutral Switch - Connector Hard to Remove
00-03-10-003B  MAY 01       Tires - Bumper To Bumper Warranty Coverage
00-00-89-008A  MAY 01       Vehicle - Precautions When Towing
99-07-30-020A  APR 01       A/T - Service Procedure Changes
01-08-97-001   APR 01       Homelink - Transmitter Test Kit
01-08-44-005   APR 01       Radio Display - Error Code Diagnosis/Repair
01-00-89-08    APR 01       Service Information 2000 - Campaign Access
01-02-32-004   APR 01       Special Tools - Power Steering System Analyzer
01-07-30-010   MAR 01       A/T - Torque Converter Replacement Guidelines
01-06-01-011   MAR 01       Engine - Oil Consumption Guidelines
01-00-89-006   MAR 01       Technical Service Bulletins - Summary
01-04-18-001   FEB 01       Driveline - Noise When Operated in 4WD
01-08-42-001   FEB 01       Exterior Lamps - Condensation & Replacement Guidelines
00-00-89-15A   FEB 01       Warranty Administration - Repair Order Documentation
00-08-48-005   DEC 00       Glass - Distortion Explanation
00-00-89-029   DEC 00       Vehicle - Warranty Labor Time Guides Update
99-00-89-019A  DEC 00       Warranty - Parts Return Program
00-07-30-022   NOV 00       A/T - 4L60E No Reverse, 2nd, or 4th Gears
00-00-89-027   NOV 00       Interior - Odor Elimination Product
00-00-90-001   NOV 00       Suspension - Chassis Lubrication Importance
00-03-10-006   NOV 00       Tires - Radial Force Variation
00-00-89-025   NOV 00       Vehicle - Labor Time Updates
00-00-89-023   OCT 00       Labor Time Guide - Update
00-01-38-007   SEP 00       A/C Performance/Leaks - Diagnostic Procedure
00-00-89-020   SEP 00       Labor Time - Updates September 2000
00-08-46-002   SEP 00       OnStar® - Cellular Antenna Replacement Parts Available
00-00-89-021   AUG 00       Cross - Line Warranty
00-00-89-019   AUG 00       Electrical Relay - Labor Operation Numbers Update
00-06-04-033   AUG 00       Emissions - Enhanced Inspection Program Manual
00-06-02-006   AUG 00       Engine Coolant - Information
00-00-89-017   AUG 00       Labor Time Updates - August 2000
00-00-89-014   JUL 00       Labor Time Updates - July 2000
00-00-89-012   JUN 00       Labor/Time Guide - Updates
00-06-04-026   JUN 00       PCM - Returned Product Feedback Program
00-06-03-006   JUN 00       Settlement of Lawsuit on Batteries (CA Proposition # 65)
99-01-38-006A  MAY 00       A/C - Refrigerant Recovery/Recharge Equipment
00-06-03-003   MAY 00       Battery - Testing and Replacement
00-05-22-004   MAY 00       Brake Fluid - Level & Filling Recommendations
00-06-04-021   MAY 00       EVAP System - Service of Connectors
00-06-01-012   MAY 00       Gasket surfaces - Using Abrasive Disks
00-00-89-010   MAY 00       Labor Time Guide - May, 2000 Update
00-00-89-004   APR 00       April, 2000 Labor Time Guide Updates
99-00-84-021B  APR 00       GM Dealer Parts Procurement
00-06-04-014   APR 00       No/Hard/Slow Start, Backfire/Kickback During Crank/Start
99-01-39-007A  MAR 00       Automatic Air Conditioning Operation
00-03-10-002   MAR 00       Chemical Staining of Chrome Wheels.
00-06-01-007   MAR 00       Rod Bearing Clearance Checking Tool
00-05-22-002   FEB 00       (Warranty) Brake Rotor Service Procedure
00-06-04-011   FEB 00       Evaporative Emission Testing on Vehicles
00-00-89-001   FEB 00       February, 2000 Labor Time Guide Updates
99-09-41-004   JAN 00       Air Bag (SIR) On-Off Switch Kits, New Parts and Service
99-00-89-023   JAN 00       January, 2000 Labor Time Guide Updates
00-06-04-003   JAN 00       ROUGH IDLE AFTER START, AND/OR SERVICE ENGINE SOON LIGHT
99-09-40-004   JAN 00       TOP TETHER HARDWARE PACKAGE FOR CHILD RESTRAINT SEATS
99-06-03-012   DEC 99       Battery Testing and Replacement
99-00-89-021   DEC 99       December 1999 Labor Time Guide Updates
99-04-20-002   DEC 99       Driveline  Clunk
99-01-38-006   DEC 99       J-43600 ACR2000 Refrigerant Recovery/Recharge Equipment
99-00-89-022   DEC 99       The Year 2000 and Vehicle Electronics
99-08-45-005   NOV 99       Accessory Receptacle/Cigar Lighter is Inoperative
99-00-89-020   NOV 99       November 1999 Labor Time Guide Updates
99-08-46-001   NOV 99       OnStar® Kit Part Numbers and Compatibility
99-06-04-053   NOV 99       Powertrain Control Module Reprogramming
99-08-64-028   NOV 99       Procedure for Aligning Rear Side Door
99-08-42-009   NOV 99       Setting of I/P Dimmer Control to View PRNDL Display
99-07-30-021   OCT 99       New Solenoid Testing Kit For All Hydra-Matic Trans.
99-00-89-017   OCT 99       October, 1999 Labor Time Guide Updates
99-06-02-017   OCT 99       Radiator Repair/Replacement Guidelines
99-08-51-007   OCT 99       Refinishing Aluminum Wheel
99-08-52-005   OCT 99       Remote Keyless Entry Operational Characteristics
99-00-89-016   SEP 99       1994-2000 Labor Time Guide - Updates
99-07-30-017   SEP 99       Auto/Trans Oil Cooler Flushing and Flow Check Procedures
99-05-24-001A  SEP 99       Brake Lead  /  Pull and Front Brake Wear
99-08-64-016   SEP 99       Use of Silicone for Weatherstrip Maintenance
000000A        JUL 99       GM Service Bulletin Precautions
99-00-89-010   JUL 99       July,1999 Labor Time Guide Updates
99-00-89-008   JUN 99       June 1999 Labor Time Guide Updates
99-03-10-102   JUN 99       Original Equipment Chrome Plated Aluminum Wheel ID
99-04-20-001   JUN 99       Rear Axle Lubricant Compatibility and Usage
99-08-110-005  JUN 99       Sunshade Replacement
99-00-89-006   MAY 99       May 1999 Labor Time Guide Updates
99-00-89-004   APR 99       1994-2000  Labor Time Guide Updates
99-08-49-006   APR 99       Cleaning of  Upper Instrument Panel Surfaces
99-06-01-003   APR 99       Engine Bearing Knock Noise
99-08-51-001   APR 99       Paint-less Dent Repair Process
99-00-89-003   MAR 99       1994-2000 Labor Time Guide Updates
99-06-03-002   MAR 99       Battery Insulator Replacement
99-07-30-005   MAR 99       Component Slipping/DTC P1870 Diagnosis
99-06-03-001   MAR 99       Essential Tool J 42000 Battery Tester
83-81-34       MAR 99       Operating Vehicle with SIR Warning Light On
99-00-89-002   MAR 99       Using the New GM Service Bulletins
99-00-89-001   FEB 99       1994-99 Car and Truck Labor Time Guide Updates
99-06-04-006   FEB 99       Correct Solvent for CSFI Poppet Cleaning Procedure
83-05-11       JAN 99       1994-99 Labor Time Guide Updates
83-12-21       JAN 99       Contaminated R134a A/C Systems
86-05-02       DEC 98       Delayed Warranty Start Process
83-05-10       DEC 98       Labor Guide Updates for 94/99 Cars and Trucks
87-71-74       NOV 98       1-2 Accumulator Piston and Outer Spring Replacement
83-05-09       NOV 98       Labor Time Guide Updates for 1994-99 Cars and Trucks
83-01-20       NOV 98       Temporary Changes to Techline ESI Applications
83-32-10       NOV 98       Tool J 43435 Adjuster Locknut Wrench
83-32-09       NOV 98       Tool J 43485 Power Steering Bleeder Adapter
86-90-06       OCT 98       Information on Reduced Range/Operation of (RKE)
83-05-08       OCT 98       Labor  Time Guide
83-15-16       OCT 98       New Windshield and Glass Urethane Adhesive Caulking Kit
76-02-02A      OCT 98       Recommended  Axle  Lubricant
83-81-32       SEP 98       Information On New PCM Connector Service Kits
83-05-07       SEP 98       Labor Time  Updates
86-74-04       SEP 98       Low Transmission Fluid Level, Transfer Case Overfilled
86-32-06       SEP 98       Reduced Steering Effort
83-02-01       SEP 98       Revised Crankcase Ventilation System Maintenance
76-43-01A      SEP 98       Slow/No Engagement of Front Axle when 4WD Selected
83-83-16       SEP 98       Speedometer Accuracy
43-17-01B      AUG 98       Bumps or Rust Colored Spots in Paint
84-96-01       AUG 98       Correct Labor Code Usage for Entertainment Systems
86-43-06A      AUG 98       Fluid Leak Near Front Wheels or  Front Engine Area
83-90-12       AUG 98       Keyless Entry Transmitter Tester
83-05-06       AUG 98       Labor Time Updates
80-05-03       AUG 98       Redefined Use of Parts Warranty Special Claims B and C
68-05-02B      JUL 98       Courtesy Transportation Administration Guidelines
86-43-08       JUL 98       Differential Carrier/Output Shaft/Bearing Replacement
83-05-05       JUL 98       Labor Time Guides Updates
81-65-40       JUL 98       No Serial Data Diagnostic Procedure
83-96-05       JUL 98       Radio Telephone/Mobile Radio Inst/Troubleshooting
77-60-02       JUN 98       Acc Drive Belt Noise/Pwr Steering Pump Pulley Misaligned
36-71-03A      JUN 98       Automatic Transmission External Oil Cooler
83-90-08       JUN 98       Charts and Schematics for Cruise Control Diagnosis
76-83-03A      JUN 98       Fuel Gauge Indicates Empty w/ 7-8 Gals Left in Tank
83-05-04       JUN 98       Labor  Guide Time Update
82-05-03       MAY 98       Elimination of Labor Op Z7920/Z7930
82-05-05       MAY 98       General Motors Warranty Inquiry System
83-05-03       MAY 98       Labor Time  Guide  Updates
83-71-10       MAY 98       Park/Neutral Switch Conn. Cannot Be Removed
82-05-02       MAY 98       Request for Authorization Using Routing Code  H
83-05-02       APR 98       Labor  Time  Guide Updates
87-61-24       APR 98       Use of Surface Conditioning Discs
48-05-01C      MAR 98       Customer Concern Not Duplicated /Verified - Labor
87-63-02       MAR 98       Excessive Ticking Noise in Ambient Temperature
83-83-07       MAR 98       Fuel Level Sensor Replacement Procedure
83-05-01       MAR 98       Labor  Time  Guide  Updates
61-65-60A      MAR 98       Revised DTC P1345
81-65-36       MAR 98       Revised Enhanced Ignition System Diagnostic Procedure
83-64-09       MAR 98       Tool J 41450-B Released for CS Generator Diagnosis
83-01-14       MAR 98       VIN Plate Replacement
72-05-09       FEB 98       GM Dealer Empowerment Program
73-05-09       FEB 98       Labor Guide Updates
82-05-01       FEB 98       New Vehicle / Replacement Battery Warranty Instructions
81-65-37       FEB 98       Revised Engine DTC's P0137, P0172 and P0420
73-50-37       JAN 98       Brake Rotor and Hub Cleaning Tool Revision
72-05-14       JAN 98       Enhanced Sublet Repair Policy
73-90-23       JAN 98       Frontal (SIR) ON-Off Switch Kits, Parts and Procedures
73-05-09       JAN 98       Labor Times Update
72-05-13       JAN 98       Repair/Replace Policies and Procedures
72-05-12       JAN 98       Shock Absorbers and Struts Operations
73-05-07       DEC 97       Labor  Time Guide Updates
77-71-77       DEC 97       Loss of 4th Gear/Busy 3-4 Shifting/TCC Cycling
72-05-11       DEC 97       Rail Dust Removal and Chemical Spotting - labor
71-05-02       DEC 97       Recall Campaign Follow-Up Post Card
73-01-10       DEC 97       Technical Assistance Call Preparation
48-05-01A      NOV 97       Customer Concern Not Verified/Duplicated Labor Operation
78-83-03A      NOV 97       Identification of the Instrument Cluster
62-05-02A      NOV 97       Labor Operation Z1241 - Personal Property Damage
73-05-07       NOV 97       Labor Time Guide  Updates
77-65-23       NOV 97       On-Board Diagnostic System Improvements
73-12-13       NOV 97       PureGuard 2 Operating Alert
77-71-68       OCT 97       Cooler Flush Adapter for 4T40-E and 4L60-E
73-90-18       OCT 97       Diagnostic Hints for Rolling Code (RFA) Systems
76-11-01       OCT 97       HVAC Control Knob Spins Freely
73-05-06       OCT 97       Labor Time Guide Addition
73-01-09       OCT 97       Revised Repair Procedures for Inoperative Ign. Cylinders
67-61-14B      SEP 97       Engine Noise
73-05-06       SEP 97       Labor Time Guide addition
73-62-13A      SEP 97       Servicing of Aluminum Heater Cores and/or Radiators
70-05-01       SEP 97       Tire Replacement During Bumper to Bumper Warranty
77-71-67       AUG 97       Diagnosis of Transmission Noise and Delayed Engagement
72-05-04       AUG 97       Guidelines for Claiming C0034 - Windshield Replacement
72-05-06       AUG 97       Guidelines for I/M 240 Labor, J9980-I/M, J9981 and J9982
72-05-05       AUG 97       Guidelines for Using E0420 Wheel Replace
72-05-03       AUG 97       Guidelines for Wheel Alignments and Wheel Balance
73-05-05       AUG 97       Labor Times
76-81-13       AUG 97       Revised Audible Warnings, Circuit Operation
76-82-08       AUG 97       Revised Convenience Center Table
71-65-36       AUG 97       Revised DTC P1406
76-81-10       AUG 97       Revised Interior Lights, Circuit Operation
76-81-14       AUG 97       Revised Table for Fuel Gauge is Inaccurate
76-81-12       AUG 97       Revised Table for Keyless Entry Does Not Operate
76-81-15       AUG 97       Revised Table for Wipers Will Not Shut Off
73-62-13       JUL 97       Aluminum Heater Core and/or Radiator Replacements
67-61-20A      JUN 97       6.5L Diesel Engine Product Update
73-05-04       JUN 97       Labor Time Update
63-17-07B      JUN 97       Paint Specification for Basecoat/Clearcoat Paint Systems
76-30-01       JUN 97       Steering Wander
76-50-08       MAY 97       Cloudy, Strawberry-Colored Parking Brake Fluid
71-65-40       MAY 97       Enhanced Ignition System Description and Operation
76-50-09       MAY 97       Revised ABS Diagnostic Information
73-10-54       MAY 97       Two-Part Urethane Adhesive For Windshield Installations
631208A        APR 97       A/C Tool And Equipment Maintenance
77-71-53       APR 97       Chuggle/Surge on TCC Apply/No DTC's
77-64-04       APR 97       Distributor Service Kits
76-16-12       APR 97       Easy Entry Seat Noise, Movement, High Adjustment effort
661509A        APR 97       Fiber Glass Rear Fender Paint - Star Shaped Crack
73-83-15       APR 97       Fuel Gauge Responds Slowly After Fueling
73-05-03       APR 97       Labor  Time  Guide  Update
730503         APR 97       Labor Times Guide Update
620504         APR 97       Operating Procedures
730107         APR 97       Revised Supplemental Inflatable Restraint Warning labels
549001A        MAR 97       CLN Indicator On Radio Display
67-61-14A      MAR 97       Engine  Noise
766504         MAR 97       Malfunction Indicator Light (MIL) On, Poor Driveability
676540         MAR 97       Pictorial Of Oxygen Sensor Designations
736513         MAR 97       Reprogram Capability Using Off Board Program Adapter
731204         FEB 97       Air Conditioning Systems With R12 Or R134a Service Issue
731049         FEB 97       Body Sealer Tape For Collision Repairs
768102         FEB 97       Courtesy Lamp Dome Lamp Remain On
739005         FEB 97       Inflatable Restraint I/P Module Remove/Install Procedure
616316         FEB 97       Injection Balance Test Procedure Revised
668131         FEB 97       Power Windows Revised Chart
730501         FEB 97       Update Labor Time Guide
730502         FEB 97       Updates Labor Time Guide
630507         JAN 97       Updates Labor Time Guides
649601         JAN 97       Compact Disk Players Procedures
569603A        JAN 97       Electrical Interference In Mobile (Two Way) Radio
436407A        JAN 97       Low  Voltage Reading Or Dim Lights At Idle
600503         JAN 97       Warranty Repairs And Claims Procedures
677163         DEC 96       Automatic Transmission
61-65-59       DEC 96       Need to Clear DTC's After PCM, VCM or EGR Servicing
63-05-06       DEC 96       Updates to Labor Time Guide
310503C        DEC 96       Warranty Claim Processing
677157         NOV 96       1997 4L80E Transmission Product Updates
631215         NOV 96       A/C Compressor Seal Washer Reference Chart
610111         NOV 96       Key Code Information
377148A        NOV 96       Transmission Shift Solenoid Update
669002         NOV 96       Under Hood Reel Lamp
689601A        OCT 96       Radio Repair Centers and Warranty Information
670502         OCT 96       Submission of OBD II Codes with Warranty Claims
630504         OCT 96       Warranty Administration Labor Time Guide Updates
630505         OCT 96       Warranty Labor Time Guide Updates
400501A        SEP 96       Corporate Parts Return Program Instructions
677151         SEP 96       New Product Information
319004A        SEP 96       SIR Module Shipping/Return Procedure
661206         SEP 96       Section 1B - HVAC - Updated
67-71-49       JUN 96       Revised Text For All DTC Tables
68-05-03       JUN 96       Goodwrench® Service Plus Lifetime Service Guarantee
252 of these.
#2 Shaners
Shaners
    Senior Enthusiast
  • Moderator
  • 8,936 posts
  • Gender:Male
Posted 03 February 2002 - 05:34 PM
I believe GM only contacts owners for a "recall" or safety related item.  A TSB is basically an acknowledgement from GM to it's dealers about a potential problem that could occur with some vehicles, and it describes the symptoms and explains how to correct the problem, so the dealer is able to quickly take care of it for the consumer.
2013 Avalanche LTZ. White Diamond Tricoat paint w/Ebony leather. (mine)  In person tune by Justin from BlackBear Performance
2005 BMW 645Ci convertible w/only 21k miles
2013 Ford C-Max SEL Hybrid (hers)
Please PM me if you have any questions or concerns.
#3 CapnDean
CapnDean
  • Member
  • 323 posts
Posted 03 February 2002 - 11:56 PM
TSB's do not require owner notification.  RECALL's do!
Basically a TSB can be anything from an acknowledged problem that exists......to a simple technique that makes a service task easier.
Just because you have a pile of TSB's does not mean you have a heap...it more than likely means that there are a bunch of them on the road.
Most tsb's only affect a few vehicles, some affect ALL in a given category.
Look at the GM A/C odor problem....If you never have it...great.  If you do, they will put a heater in your duct to dry out your evaporator core.
Dean
2006 LBZ 2500HD Duramax EFI  Live, FASS, PCV Reroute, EGR Block 25 mpg
#4 TxDoc
TxDoc
    Senior Enthusiast
  • Member
  • 1,096 posts
  • Gender:Male
Posted 04 February 2002 - 01:18 AM
Thanks for the explanations.
#5 Sarah99GXE
Sarah99GXE
  • Newbie
  • 327 posts
Posted 04 February 2002 - 06:11 AM
yeah that helps me out alot too...
