Green04
Extended cab rear windows - wind noise
:rolleyes: I don't like the excessive wind noise from the pop-out windows on my extended cab. GM replaced the gaskets, and that seemed to help until it got cold. Now it's as bad as ever. (To add insult to injury, they really chipped up my paint around one of the windows and did a lousy job fixing the chips! :D )
BESIDES, gluing them shut, has anyone had these pop-out window seals replaced and gotten a significant reduction in noise?
Share this post
Link to post
Hey i also have the same issue with my ex-cab but just havent gotten around to fixing it. I work at a gm dealer here in maryland and just was online reading about this tsb, when i read your thread the tsb# is pit3787 and it looks like it is saying to adjust the rear quarter glass hinge so it pulls the glass tighter to the body of the truck. but if you can pull up that bullitan or see if some one has it and check it out
Share this post
Link to post
I had both of mine replaced by the dealer and no problems since.
If I was you, I would take it back in and have both the window and chips fixed right.
Share this post
Link to post
They JACKED UP YOUR PAINT! THEY need to fix it, PERIOD! They have plenty-o-cash.
good luck w/ the windows too.
Share this post
Link to post
SO how do you adjust the hinge on that window???
Share this post
Link to post
d**n I have the same problem on my 1998 silverado but only on the 3rd door.
To me it looks like the latch isn't pulling the window in tight enough, I will be investigating the latch mechanism further to see if I can adjust it. :D
Share this post
Link to post
The hinges are not adjustable. The only way to fix is to pull the window and reset it deeper in the window pocket of the sheet metal. That means using less window adhesive. If that is not deep enough they will have to get another window assembly and hope that it is "tighter".
My dealer replaced the 1/4 windows in my 2000 Sierra for this conditon and the windows that came from the factory were both loose. They got new ones and set them with less adhesive and they were fine.
My 2002 had the driver side 1/4 window loose. Again the dealer replaced it but this time they reused the window with less adhesive.
Very common problem.
Yeah, get the dealer to repair the abuse to the paint. They will haunt you a couple years from now. It will rust and leak......
Give em hell!
Share this post
Link to post
Hi everyone i am new, and your site is awsome.
Anyway i have a 99 silverado ext cat with that wind noise problem and i heard about this replacement part that they sell on eBay i just bought it and havent gotten it to put it in yet.
here is the link:
Link
I will post an update on how it works but from what i heard it is the best $37 sopme people have spent in a long time.
Share this post
Link to post
I am problems with my 2000 model and they replaced one of the windows and on the other they had some type of screw they added to tighten up the latch. Never had a problem with them after that.
Share this post
Link to post
lawnscapes2: let us know as my 2000 has both windows making noise and I'd like a fix for them. Thanks
Share this post
Link to post
Looks like they are still having probs with these windows. My 2005 GMC 1500 ext. cab has really bad windnoise on the passenger rear 1/4 window. They are replacing the whole window and frame assembly. Guess they get glued in wrong at the factory or something. The body shop manager said he sees quite a few of these and this is the only sure fire fix.
Share this post
Link to post
There was a fix to stop the leak by adding the screw to the latch way back in 2000. It works well two of my business trucks have had it done.
Share this post
Link to post
Yeah let us know how it works...ive been wanting to do something about mine and for 37.00, id sure give it a try
Share this post
Link to post
