Gentlemen,
How common are clogged cat converters. I had one clog on a MotorHome once and it was an interesting experience. I am concerned about mine.
Ken
Share this post
Link to post
I've never had a clogged cat. My '95 K3500 went 155,000 miles on the original and still had low back pressure.
It's important to fix any "miss" or SES condition quickly so as not to degrade the cat.
But if you've had misfiring, especially if it's been happening for a while, consider your catalytic converter's life to be diminished accordingly and your exhaust system back pressure to be higher also.
Higher back pressure lowers your engine's theoretical maximum efficiency (your mpg will suffer).
Share this post
Link to post
very unlikely
And only likely if one adds a lot of additives on a chronic basis that aren't cat friendly to the fuel. We also have a few 150,000+ mile vehicles with the original exhaust with cats. No problem at all with them.
Share this post
Link to post
I had a 2003 5.3 Z71 Avalanche that had a clogged cat (passenger side) at 60,000 miles that was covered under warranty.
Share this post
Link to post
Yelp, PCMs and converters covered 8 years 80,000
Share this post
Link to post
clogged cats would be from too much sulfer in the fuel, such as some found in Mexico or way too rich with saturates the substrat material with fuel or way too lean which creates high temps causing melting of the substrat.
Then as some have experienced...not necessarily clogged, but classified as screwed when parking over tall dry grass...flame on!
Share this post
Link to post
I just had mine replaced after 170,000 miles. It has been clogged for about 10k that I can remember, I lost a lot of power and in the last days, the motor did not want to stay running at idle. With the new high flow cat, the truck is once again a beast, of course, the tranny is still in need of a rebuild, but it is still a beast.
Share this post
Link to post
When mine was clogged on the motor home, I got a chance to look at it. It seemed to be simply dirt, almost like vacuum cleaner dirt. I think bad air filtration could be at fault. If you take off the air cleaner, dirt will go right through the motor and lodge in the tiny converter passages.
Ken
Share this post
Link to post
My 96 K1500 silverado 5.7 Vortec keeps giving me a code "P0430 = Catalyst Efficiency Below Threshold (Bank 2)". I've replaced the O2 sensors fairly recently so i don't think that is the problem. This truck has 163,000 miles and the catalytic convertors have never been replaced. Does that sound like the problem and if so is there a fairly cheap universal replacement for both catalytic convertors? I know the factory set up with pipes to the manifolds is $300-$500 so i'd rather cut out the old cats and weld in new ones if possible. It also has a "P1403 code = EGR valve pintle position" could this be causing the P0430 code to happen?
Share this post
Link to post
