Reduced Engine Power Message
  • Please log in to reply
32 replies to this topic
#31 Eljefe8669
Eljefe8669
  • Member
  • 2 posts
  • Name:Charles A Williams
  • Drives:2004 gmc sierra 2500hd gas
Posted 05 September 2016 - 05:10 PM
I buy around 100 chevy trucks a year so I am very familiar with this issue.
99% of the time the reduced engine power is due to the gas pedal. I always replace that first.
Second is wiring going to the TB itself. Dorman makes a kit with a new harness and TB motor. I have never seen the motor fail but I have found two bad harness connections.
The third is the TAC Module on the firewall driver side. I have only seen a TACs Module fail once.
Replace the gas pedal and im sure all will be fine.
#32 Eljefe8669
Eljefe8669
  • Member
  • 2 posts
Posted 05 September 2016 - 05:11 PM
I have replaced the throttle body and none of the wires appear to be loose but I do have a new harness. So the next step could be the gas pedal sensor correct?
#33 SpartanAutoworx
SpartanAutoworx
    GM Truck Salvage King ;)
  • Member
  • 217 posts
  • Name:Erik
  • Gender:Male
  • Drives:LSA Swapped 2500HD Silverado with Prior Salvage Title -_-
Posted 06 September 2016 - 11:01 PM
Replace the entire gas pedal. Its around $60 brand new wholesale from GM. Not sure what list is on it.
GMT-800 Parts and Factory Module programming specialist  :pimp:
2004 Silv2500 2WD LSA Swap with LSX Precision Adapters and Front Runner Kit
2001 SIlv2500 2WD Turbocharged by LSX Precision with LSX Precision Turbo Manifold
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
