I did do a search and came up with nothing on the topic of upgrades for my 6.0L. I have a slightly used '01 GMC 2500HD SLE ext cab short bed with 4.10's and stock P245 tires. :thumbs:  Love the truck and so far am unimpressed with the mileage. 11-13mpg. Can anything be done about it? K&N does not list a FIPK for it and the programable unit is a lot of money for a single use.
Thanks for your time,
Mike
Share this post
Link to post
Go to Performance Products and look for a listing for FIPK kits for your truck. The K & N part number for the kit is 57-3031. I got mine from there about 3 weeks ago. It was just released from K & N around Thanksgiving time.
Also if you go to Flow Master you can find out info on the new flowmaster muffler made for the 6.0l and 8.1l Big Block Muffler for your truck.
Bruce   :thumbs:
Share this post
Link to post
Bruce, thanks for the P/N's. Have you installed both on yours yet? Have you noticed any difference Before/After. I am fighting 10.4mpg in town and hoping to correct that.
Share this post
Link to post
I've run only one tank of gas thru the truck since I put on the K&N FIPK. I have not calculated the mileage as of yet. It was a combination of normal driving and towing my trailer. So it would not be a good indication. I also heard it takes a couple tasks of gas for any solid results come about. I know the famous seat of the pants DYNO says it has better acceleration in the higher RPM ranges. I wont be putting on the new muffler for a few months. I just bought another car and the pockets are a little on the lean side. Labor is so expensive here in the Bay Area, it's not the price of parts, it's having them installed. I go to a speed shop for the muffler work, they know what they are doing with a welder.
Bruce
Share this post
Link to post
From my past experiance with my 5.3L I got about 1/2 mpg increase with the FIPK.  I don't know if you'd see that with the 6.0L, but it would be nice.  I have a K&N drop-in in my 6.0L but the colder weather isn't helping my mpg's...
Share this post
Link to post
www.performanceproducts.com really doesn't have a lot yet for the HD's.  Gibson does have two cat-back systems available (dual out the passenger side and then the two out the back), Volant, AirAid and K&N have cold air kits available.
I changed my lightbulbs immediately with PIAA's (from Performanceproducts.com
Share this post
Link to post
To bad you don't have a Duramax, I could direct you to some
electronic "boxes" that give about 120Hp and 200ft-lbs.  Not
to mention they only take about 20 minutes to install, and
about 5 to remove.  Don't know of anything out there for the
gassers though.   :thumbs:
Share this post
Link to post
Tell me about it Kansas.  I am eagerly awaiting a heads and cam package for the 8.1!  496 cubes is a terrible thing waste if you don't allow it to breathe more efficiently.  :thumbs:
Share this post
Link to post
Your wait is over... have checkbook ready
New 8.1 Liter Big Block GM Camshafts
COMP Cams® is producing some big-time power with their new series of cams designed and manufactured for GM’s 8.1 Liter Big Blocks. These high strength steel cams are available with various stock or custom grinds, and are precisely profiled to maximize the power curves required for drag racing, powerboats, tractor pulls, and other extreme use applications.
To find out more technical and application information, contact COMP Cams® at 1-800-999-0853.
Part # 46-408-9 Great torque, good for towing & RV’s. Works with O.E. exhaust and intake
Part # 46-413-9 Good midrange performance, great for daily driver, headers recommended
Part # 46-422-9 Best in performance applications, after-market intake and exhaust recommended
See pdf for picture
http://www.compcams.com/information/WhatsN...ess/8-1cams.pdf
Share this post
Link to post
