Coachmenguy
6.0L coolant leak????????
the other day i went to my buddies shop to change the oil, we got it up in the air and noticed coolant coming from the front of the motor, water pump looked dry, we couldn't trace it because of all the stuff in the way, but i traced it as far as the front of the oil pan where it meets the block. i know its not coming from there but thats as far as i could see. i know trans fluid is also pink but this did not appear to be trans fluid and all trans lines were dry. SO WHAT THE HELL IS GOIN ON??? now im not talkin a small wet spot, im talkin enough to make droplets. so any pointers on this would be great, i drive it normaly dont beat on it too often and its only got 43000 on it so this shouldnt be an issue!
Share this post
Link to post
water pump gaskets
Share this post
Link to post
If you find it is the Water Pump gskt, I would stongly suggest that you go ahead and replace the pump while you have it off. Some of these pumps last forever but we do seem them going out before 100K sometime.
Share this post
Link to post
