- 0
3500 Dually - Distinct Vibration at 35-45 mph
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 4 Members, 0 Anonymous, 545 Guests (See full list)
Question
davereid
2006 K3500 D/A DRW Crew Cab 12,500 miles - Vibrates at moderate speeds.
I first noticed a vibration during around town driving the day after I took delivery.
It was probably already there but it's only noticeable in a particular window, 35-45 mph, and coincidently, at about double that speed only it's much more rapid and less annoying at higher speed.
The vibration is distinct to the point that inside a cab with windows up, it produces an annoying fluttering sound at it's worst, right about 38 mph. At its' worst, the empty passenger seat next to me shakes visibly and constantly.
The vibration happens at that speed no matter what the circumstances are, I have tried accelerating, braking, coasting through, and coasting in nuetral, and using all gears in that range, the only common denominator is the speed, however it seems worse at the moment when I let off the pedal if I'm at that speed under throttle. It has never not vibrated at that speed. At other speeds it seems normal, after 45mph it goes away but at a little over 70 mph the ride becomes rough again up to around 80-85.
It's not bad at all if I'm not at those speeds, but it's bad enough every time I feel it I know there is something wrong with this truck. Both the service manager and general manager at my dealership agree.
Corrective actions to date:
Balance all six tires. No improvement. 1000 Miles
Balance and road force all tires, replace two. No improvement. 1500 Miles
Balance and road force all tires, replace two. No improvement. 9000 Miles
Replace with Michelin LTX, balance, roadforce, index, etc, same result, no improvement. Go back to stock tires - Wrangler AT/S from factory, balanced, indexed, same vibration remains. 10,500 Miles (never thought I'd return LTXs)
Balance front and rear driveshafts. No improvement. 10,500 Miles
This seems like a no brainer, if the vehicle shakes while rolling, it's tires or wheels. So far a total of 16 tires have been introduced, all balanced and indexed by the dealer. The dealer says the wheels are checked at the factory, so they must be perfect, and at this point all wheels are balanced to within acceptable tolerances. I have to say at all other speeds the ride is excellent. Has all this work on wheels and tires proved it ISN'T that or should the wheels still be measured somehow. Or does this sound like something else to you?
The dealer has been very cooperative in attempting to locate and repair the problem, and remains eager to solve it, but obviously we are missing something, where should they go from here?
0 answers to this question
