TJCamro
How do you turn off Headlights?
How do you get you auto headlights to turn off? I need to shut them off when going on base and dont know how.
Share this post
Link to post
If your truck is an early 2000 then most likely the dome overide trick won't work...
Share this post
Link to post
You turn the switch momentarily to the off position. It will return to auto because it is spring loaded and cannot be left in the off position. The lights willbe turned off. The lights will remain off until you shut off and restart the truck.
Share this post
Link to post
Unfortunately, not on a 2000.
Share this post
Link to post
My 99 was like that. There was no way to turn off the auto headlights. :P At least GM learned from that screw up. They went to the dome override thing for part of the 2000s I think and the '01-'02s before allowing you to turn the headlight switch to the left to turn them off on the '03s and later.
Share this post
Link to post
My fiancee`'s '99 Jimmy is like that. There is no factory way to turn off the automatic headlights. Don't really feel like rewiring it or I'd do that.
Share this post
Link to post
Try applying light pressure to the emergency brake and see if that does it...
Had to do it that way on 04 Dodge 2500 truck..
Share this post
Link to post
Try turning the headlight switch to the parking lights. In my 05 I can do that or turn it to the off position and it turns all the lights off. The other way just turns off the headlights. To turn them back on turn the switch back to auto.
Share this post
Link to post
TJ.......You in between a rock and a hard place !
99 and early build 00s you cannot to the pushbutton to overide trick.
To disable the DRLs either pull the bulbs or go to http://www.lightsout.org
To disable the auto-on headlights check out this post( I did on my 01)
http://www.fullsizechevy.com
Go to the tech articles links for full instructions.
..............geo
Share this post
Link to post
Guest chevydeerhunter
Your profile says you have a '00 Sierra so the dome override trick(3 on and off cycles) should work.
Share this post
Link to post
I go on to Ft. Campbell every night with my 99 Silverado, lights blazing bright. I have never had a gate guard say anything about it. I am sure they realize that many people are not able to turn off their lights. They can't give you a ticket for something you can't control. Same for some old cars that didn't come with seatbelts. If they didn't come from the factory with belts then you don't legally have to have them in your car.
Share this post
Link to post
Yeah but that can cause other issues down the road...Not worth my time to have my fiancee` freaking out about her brakes.
Amen to that...My '68 Firebird only came with lap belts in the front seat...The only reason it's going to have 5 point harnesses in the front seat is because it'll be capable of 11's in the quarter...I'll probably move the lap belts to the back seat.
Share this post
Link to post
