yeehaw87
Rear End Torque Specs
I am looking at putting a Lock-Right locker in my truck, and I need torque specs so nothing comes apart in there. Does anyone know where I can find this information, I searched the forum and couldn't find anything. Thanks for your help.
Share this post
Link to post
Rear Axle Fastener Tightening Specifications
Axle Flange Bolts (10.5 Inch Axle)
156 N·m
115 lb ft
Axle Shaft Cover Bolts (11.0 Inch Axle)
21 N·m
15 lb ft
Bearing Cap Bolts (8.6 Inch Axle)
75 N·m
55 lb ft
Bearing Cap Bolts (9.5 Inch Axle)
85 N·m
63 lb ft
Bearing Cap Bolts (10.5 Inch Axle)
185 N·m
136 lb ft
Bearing Cap Bolts (11.0 Inch Axle)
115 N·m
85 lb ft
Brake Backing Plate Bolts (Except 11.0 Inch Axle)
140 N·m
103 lb ft
Brake Backing Plate Bolts (11.0 Inch Axle)
105 N·m
78 lb ft
Brake Hose Bracket Bolt
22 N·m
16 lb ft
Brake Pipe Junction Block Bolt
22 N·m
16 lb ft
Brake Pipe to Rear Axle Bolts
22 N·m
16 lb ft
Differential Bearing Adjuster Nut Lock Bolt (9.5 Inch Axle)
26 N·m
19 lb ft
Differential Bearing Adjuster Nut Lock Bolt (10.5 Inch Axle)
27 N·m
20 lb ft
Differential Housing Cover Bolts (Except 11.0 Inch Axle)
40 N·m
30 lb ft
Differential Housing Cover Bolts (11.0 Inch Axle)
47 N·m
35 lb ft
Drain Plug
33 N·m
24 lb ft
Fill Plug
33 N·m
24 lb ft
Pinion Bearing Cage Bolts (10.5 Inch Axle)
88 N·m
65 lb ft
Pinion Shaft Lock Bolt (8.6 Inch Axle)
36 N·m
27 lb ft
Pinion Shaft Lock Bolt (9.5 Inch Axle)
50 N·m
37 lb ft
Pinion Yoke Nut
637 N·m
470 lb ft
Propeller Shaft Retainer Bolts (Pinion Yoke Type)
20 N·m
15 lb ft
Propeller Shaft Yoke Retainer Bolts
37 N·m
27 lb ft
Ring Gear Bolts (8.6 Inch Axle)
120 N·m
89 lb ft
Ring Gear Bolts (9.5 Inch Axle)
140 N·m
103 lb ft
Ring Gear Bolts (10.5 Inch Axle)
165 N·m
122 lb ft
Ring Gear Bolts (11.0 Inch Axle)
298 N·m
220 lb ft
Stabilizer Shaft Link Bolts
95 N·m
70 lb ft
Stabilizer Shaft U-bolt Nuts
32 N·m
24 lb ft
U-Bolt Nuts (Except 11 Inch Axle w/ Attached Washer)
72 N·m
53 lb ft
U-Bolt Nuts (Except 11 Inch Axle w/o Attached Washer)
137 N·m
101 lb ft
U-Bolt Nuts (11 Inch Axle)
253 N·m
187 lb ft
Vent Hose Retainer Clamp Bolt
23 N·m
17 lb ft
Wheel Hub Nut (Except 11 Inch Axle)
70 N·m
52 lb ft
Wheel Hub Nut (11 Inch Axle)
88 N·m
65 lb ft
Share this post
Link to post
