  • 0
teambell
Broken Tailgate Latch
Question
Yanked too hard and now it will not release, the handle is just floating with no connection to anything.
Where is the best place to get a replacement part?
Are there any issues on the replacement procedure?
Also, it is now in the closed position, the reason I could not open was I got some smooth wire stuck in the bottom of the tailgate when I was doing fence work and I was trying to yank it open because it was stuck. there is no fouling in the sides of the tailgate and none around the actual tailgate latches on the side, just in the crack at the bottom of the tailgate.
Thanks!
Share this post
Link to post
0 answers to this question
This happened to me too. A friend closed the tailgate by pulling the handle as he lifted the gate. Broke something and the gate wouldn't open. My mechanic fixed it for $80 after I cut away the Rhino lining over the bolts.
Share this post
Link to post
Bought replacement tailgate handle at Dealer ($37) and took off the three bolts on the bed side of the tailgate. The rods for each side are removed from the old handle and the new handle goes into place. Be careful with the plastic insert for the entire recessed area, it has tabs on the bottom that will break off if you aren't careful removing it.
The whole thing took 10 minutes.
:thumbs:
Share this post
Link to post
Same here and I fixed it for two bucks, pull the plastic trim piece around the handle and you can see the little plastic clips that jold the rods to the handle, replace the broken one from the outside and your done in 10 minutes.
Dan
Share this post
Link to post
Dan
I have one clip broke at the present. Is there anywhere I can obtain just the clips to replace the broken one. DD you said you fixed yours for two bucks. Where did you get the clip???
Share this post
Link to post
<br />
Same here and I fixed it for two bucks, pull the plastic trim piece around the handle and you can see the little plastic clips that jold the rods to the handle, replace the broken one from the outside and your done in 10 minutes.<br /><br />Dan
<br /><br />I have one clip broke at the present. Is there anywhere I can obtain just the clips to replace the broken one. DD you said you fixed yours for two bucks. Where did you get the clip???<br /><br /><br /><br />
Anyone?
Share this post
Link to post
I find my local hardware store such as Ace hardware pretty handy with clips, may want to try Schmucks/Kragen auto with their "HELP" packaged stuff.
Good luck.
Aaron
Share this post
Link to post
Thanks. I got one from a commercial mech.. He told me that GM is now selling these but they buy them in packs of five left and right separately. He did not know if they were sold individually. Hope this helps the next person.
Share this post
Link to post
I got my new clip at the GMC dealer.
Dan
Share this post
Link to post
