SS Crew
Access To Back Of Headlights On 2007 Sierra
I just bought some super white bulbs for the headlights for my 2007 GMC Sierra, but the problems is how the #$%! do you access the bulbs on the back of the headlight housings? The air cleaner box on the right side is blocking access and on the left, the wiper washer bottle is in the way. I tried to remove the grille to remove the whole headlight assembly, but I just can't get the lower clips out of their slots and I don't want to break anything.
The owners manual doesn't say squat about replacing the headlight bulbs - in fact, it doesn't even give you what bulb the headlights use.
Any help would be appreciated.
Thanks,
SS
Share this post
Link to post
Thanks,
SS
Sorry, can't help ya, but I will keep an eye on this thread as I would like to know too. Also, what bulbs did you get and where?? I would like to get some HID bulbs for the headlights and the fog lights.
Thanks!
Share this post
Link to post
Isn't there two L shaped rods on each headlight assembly that must be pulled up (with hood open, they are on top of each headlight) as in previous years ?
Take a look...I would hope they wouldn't design it so you need to dismantle the front end.
Share this post
Link to post
Why don't one of you guys with a NBS 900 open up your owner's manual and help this guy out?? The answer is in your glove-box.
Share this post
Link to post
OK. To replace the front headlight halogen bulbs:
1. Open the hood.
2. If you are replacing the bulb on the passenger side, remove the engine air cleaner cover.
3. Reach in and access the bulb sockets from the inside engine compartment.
4. Turn the bulb socket counterclockwise to remove it from the headlight assembly and pull it straight out.
5. Unplug the electrical connector from the old bulb by releasing the clips on the bulb socket.
6. Replace it with a new bulb socket.
7. Plug in the electrical connector to the new bulb socket.
8. Reinstall the new bulb socket into the headlamp assembly and turn it clockwise to secure.
9. Close the hood.
Note: No mention is made in the manual (p. 544) about replacing the driver side lamps. Apparently, they do not ever need replacement.
Another note: This procedure appears to be easier than replacing the lamps in my wife's CTS-V which require removal of the front bumper.
Additional Note: To replace the driver side lamps, remove the five bolts which hold down the auxilliary battery tray(anybody carrying TWO batteries?), then remove the washer bottle neck bolt, slide the bottle out of the way and access to the driver side lamps can be made.
zoz
Share this post
Link to post
The answer isn't in the manual, unfortunately.
In order to reach the passenger side bulbs you'll need to remove the air box cover at a minimum, perhaps the whole thing depending on how large your hands and arms are. The driver side is a tight squeeze but you just have to work around the washer fluid bottle. You might remove the top screw holding the neck in place for just a bit more space but. Ultimately, it's just a PITA to change them. Wish I had better news.
Vmax2007, if you want me to test out the fog light mod on some HID's, send 'em my way! :driving:
Daddy
Share this post
Link to post
I looked in the owner's manual. Accoding to the manual, you need to remove the air cleaner box lid, but taking the lid off the air cleaner box still doesnt' give you enough access, the box is still in the way.
Share this post
Link to post
1. Open the hood.
9. Close the hood.
zoz
I noticed that they went to bolting the light assembly in, but I thought that there were only a couple of bolts to remove the light housings and they'd pop out, but man, it's a major deal to just to replace these bulbs.
Share this post
Link to post
I also found it interesting that they don't say anything about the driver's side bulb. You need to remove the battery to gain access to that. It's still kind of a light fit to get your fingers in there but it can still be done. Removing the air box assembly on the passenger's side will allow very easy access to those bulbs.
Share this post
Link to post
Well I removed the air cleaner box, the battery tray, and tried to remove the window washer fluid bottle (I couldn't find the mystery bolt, but I was able to loosen it up enough) to gain access to the back of the headlights.
It turns out that GM has changed the low beams from 9006's to H11 bulbs so the $80 PIAA bulbs I pulled out of my old truck (only a month of use) won't work in this one. @#4%&! :chevrolet: But I was able to reuse the high beam Silverstars again.
Being that these "high power" psudo HID bulbs only last about a year and it's a PITA to gain access to these headlight bulbs, I'm tempted to just go the true HID route for the low beams; especially now that the DRLs work off the low beam bulbs, not separate ones. I found one site called Never Burn Out. The bulbs are guaranteed for life and the ballasts for 3 years and the kit sells for $265. Seems like a pretty good deal. Has any one else out there dealt with these guys before?
Share this post
Link to post
I have HIDs in my high and low beams. It will be interesting to see how the lows like being DRLs too.
Share this post
Link to post
I see that you've got a 2007 GMC in your avitar, did you disable your DRLs? Your lights should come on when your truck is in gear.
Who's HID system did you use?
Share this post
Link to post
I was able to slide my hand behind the assembly and change the bulbs without removing anything. My battery is in the rear by the firewall and not in the front by the headlight.
Share this post
Link to post
It's easy at the factory, i can hold the whole headlight assembly in one hand and pop out the bulb with the other lol
Share this post
Link to post
The DRLs are still active. I might look into disabling them. I'm using the HID packages with Phillips ballsts that my company sells.
Didn't realize that the battery is by the firewall of the 1500 trucks. I have dual batteries so that was in the way on the driver's side.
Share this post
Link to post
