- 0
Reduced Engine Power Codes 2135, 1515, 220, 1516
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 8 Members, 0 Anonymous, 817 Guests (See full list)
Question
jade03
help! I've had the '03 GMC sierra Z71 5.3 only few months, 2 days after purchase i got the "Reduced engine power" mess, took it to the dealer and they told me I needed to replace the throttle body (electronic), the TAC module. I first replaced the TB, it was fine for a few days, then got more codes- but not the TB code-, so I replaced the TAC module and it was fine for a few more days, then more codes w/reduced power- they were reading pedal sensor (APP)- I replaced that and didint even make it home before the reduced power. I went to all my throttle connections to make sure they were clean ect.. and they were.... (I started noticing gettting the reduced power on bumps in the road and the hotter the outside temp got) I finally looked under the fuse box and saw a rodent had chewed off the casing off of two wires (a big blue one w/single connection, and a big red one coming off the fuse block) the two could have been coming in contact w/ each other so i seperated them left the cover off and drove to work for 2 days (about 15 mi one way) NO PROBLEMS! So the wire was not damaged just the insulation i coated them withe several coats of liquid electrical tape, kept them well seperated installed the cover and every thing was fine....... for about weeks.... now in the afternoons I've got to stop three time w/ getting reduced power on the highway or residentials just to get home, it seems more likely when my rear mirror temp reads over 88*. I removed the fuse block cover and even lifted the tray and everything still looks fine..... I'm at the end of what I can think of??? (getting codes now of 2135, 1515, 1516, 0220)
0 answers to this question
