sciggs
Mileage After "low Fuel" Light Comes On
I can never remember how much more fuel mileage you're supposed to have after your light comes on. I have a 99 z71 ext cab. Anyone have some stats on what this would be? thanks in advance
Share this post
Link to post
between 15 and 30 id think. It is probably more but Im not good at gambling.
Share this post
Link to post
I know when my low fuel light came on in my '99,and my '04 also,I had about another 4 gallons of gas left.
So whatever your gas mileage is just times it by 4 (I.E. If your getting 18 MPG then you got around 72 miles until your empty)
Share this post
Link to post
Try not to let the fuel in the tank get that low as the pump depends on fuel in the tank to keep it cool, you will greatly reduce the life of the pump keeping your tank below 1/4 or lower. Just a tip for everyone.
Share this post
Link to post
Good point,I try to never go below 1/4 tank.
Share this post
Link to post
Not to mention that condensation can form and rust your fuel tank and/or fuel lines from the inside out, and mess up your fuel injectors. Car's can't run of water yet.
Share this post
Link to post
The fuel tanks on GM trucks from '99 up are plastic but yes to the rest.
Share this post
Link to post
Anytime you run out of fuel or run low and the pump will run dry doing this is like running your engine with out oil. It burns up the bearings & impellers. Guaranteed pump replacement is in your future much sooner.
Share this post
Link to post
The fuel light came on in my '05 SB over the weekend. I drove about 15 miles +/- and then filled it up. With topping it off it took 23.1 gallons. I believe (but I am often wrong) that the tank is supposed to hold 24 gallons. I figure that put me at 1.7 - 2.2 gallons (gave or take) when the light came on.
-Jay
Share this post
Link to post
I think it's a 26 gallon tank for a shortbed. Mine was for the 2500HD and the new 07 as well. Both are 6'6 but on the 1500 CCSBs it said 26 gallons as well.
Share this post
Link to post
Yep,26 gallon tank on the short-bed & standard-beds,and 34 gallon tank on the long-beds.
Share this post
Link to post
2000 Sierra, when the light comes on and I fill shortly after I end up putting about 22 gal in. So there must have been about 6 in there, and no worries for 100 miles.
Share this post
Link to post
My mistake, it is indeed a 26 gallon tank. That would put a safe estimate, as you mentioned above, right at about four gallons.
--Jay
Share this post
Link to post
I had the low fuel warning come on the HD once, and when I finally got to a gas station (was stuck in rush hour traffic after pulling a heavy trailer) I had about 2.5 gallons left.
Share this post
Link to post
Agreed, don't let your tank go empty like that (unless it's just completely unavoidable). I don't think I've ever had a vehicle that I ran down to "E," let alone below E. I'll head for a gas station by the time I see the 1/4 tank mark, or sooner. I never understood the need to constantly wait until you're running on fumes to add more gas. Those poor, abused, and unloved vehicles.... how sad... :dunno:
Share this post
Link to post
