rj013
Program Automatic Door Locks
I have recently purchased a 2001 GMC Sierra, and my friend purchased a 2002 GMC Sierra. My door lock are set to lock once I reach the speed to 15 miles an hour, and unlock when I remove the key from the ignition, His locks when the vehicle is shifted from park, and unlocks when you shift back into park. Reading his book mine is using the program for GMC with manual transmission, but mine is a automatic transmission. I just spoke to a dealer that said that he may be able to program mine to be like his, but it would cost around $50. Is there anyone that knows how an individual can program his to lock when shift from park, and then unlock when the vehicle is shifted into park.
Share this post
Link to post
If you have the steering wheel controls then it'd be pretty easy just to set it with the buttons but otherwise I think it's only reprogrammable from the BCM.
Share this post
Link to post
BCM is this some kind of tool from the dealer.
Share this post
Link to post
It's the Body Control Module, which controls the chassis components such as locks, windows, lighting, certain dash functions, etc...It can only be changed with a Tech2 tool which most dealers will have.
Share this post
Link to post
You can program the door locks without going to the dealer.
Its in the owners manual !
Sorry I forgot how I did my 01 and 04................
Share this post
Link to post
Yeah - has to do with pushing the right combinations of buttons while you hold your mouth in just the right position. On the new NBS with the four button DIC (LT2,LTZ, LT1Convience Pkg, or DIY) it is done using the third button - along with unlock, light dealy, etc etc
Share this post
Link to post
I can confirm that it's done with a series of button pushing, I dont have my manual handy but it should be in there. I think its similar to reprogramming your fob.... something like key position off start off start then unlock lock unlock lock, click your heels, and honk the horn.... Sprry I couldnt be more help, but it IS doable without paying the dealer.
Share this post
Link to post
I would suggest doing a search on this forum - Ive seen this topic a number of times. :)
Share this post
Link to post
My manual just explains how to change what locks and unlocks, like all doors lock, only drivers door unlock, ect. I have looked through the forum also with little to no luck, I will look some more though.
Share this post
Link to post
This is cut directly from my owners manual (2000 Silverado) Probably no different than what your manual says, but thought I'd post it anyway. Far as I can tell when the doors lock (at speed or with shifter movement) cannot be changed, at least not by us anyway.
Programmable Automatic Door Locks
(If Equipped)
Your vehicle may be equipped with an auto lock/unlock
feature which enables you to program your power door
locks. The following instructions detail how to program
your door locks.
To enter the program mode you need to:
1. Pull back on the the turn signal/multifunction lever
all the way toward you and hold it while you
perform the next step.
2. Beginning with the ignition in OFF, turn your key to
ON. Return it to OFF and turn to ON again. Then
return it to OFF. Once you do this, you will hear the
lock switch lock and unlock.
3. You are now ready to program the automatic door
locks. You will have ten seconds to program once
you release the turn signal/multifunction lever.
The following is a list of the available
programming options:
Press the lock side of the lock switch on the driver’s
side door panel once to turn on the automatic door
lock feature. All doors lock. No doors will unlock.
Do the same twice to turn off the automatic door
lock feature. No doors will lock or unlock. Auto
unlocking will not work if auto locking is turned off.
Press the unlock side of the lock switch on the door
panel once to unlock the driver’s door and lock all
other doors.
Do the same twice to unlock all the doors. All doors
lock and unlock. (This is the factory setting).
Do the same three times to turn off the automatic
door lock feature. No doors will lock or unlock.
You can exit the program mode any time by turning the
ignition to ON.
The automatic lock feature will lock all the doors when the
vehicle speed is greater that 15 mph (24 km/h) for two
seconds. Your vehicle left the factory programmed to have
all the doors unlock once the key is removed from the
ignition and lock when vehicle speed exceeds 15 mph
(24 km/h). See your dealer for more information.
If the lock/unlock switches are not pressed while in the
programming mode, the respective auto lock/unlock
setting will not be modified.
Share this post
Link to post
I use to have a Pontiac Grand Prix and to enter programming mode I would have to actually remove one of the fuses.
Share this post
Link to post
