Hi, I scanned my truck today, and got a code of po650. I removed the cluster to have it rebuilt, is that why I have a po650-circuit malfunction??
Share this post
Link to post
assuming that its the truck in your profile then yes its related
DTC P0650
Circuit Description
The malfunction indicator lamp (MIL) is located on the instrument panel cluster (IPC). The MIL informs the driver that an emission system fault has occurred and that the engine control system requires service. The control module monitors the MIL control circuit for conditions that are incorrect for the commanded state of the MIL. For example, a failure condition exists if the control module detects low voltage when the MIL is commanded OFF, or high voltage when the MIL is commanded ON. If the control module detects an improper voltage on the MIL control circuit, DTC P0650 will set.
Share this post
Link to post
DTC P0650
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=855341&psdid=437&evc=sm#ss1-855341">
Circuit Description
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=855341&psdid=437&evc=sm#ss2-855341">
Conditions for Running the DTC
The engine is running.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=855341&psdid=437&evc=sm#ss3-855341">
Conditions for Setting the DTC
The control module detects that the commanded state of the MIL driver and the actual state of the control circuit do not match.
The conditions are present for a minimum of 30 seconds.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=855341&psdid=437&evc=sm#ss4-855341">
Action Taken When the DTC Sets
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=855341&psdid=437&evc=sm#ss5-855341">
Conditions for Clearing the MIL/DTC
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=855341&psdid=437&evc=sm#ss6-855341">
Test Description
The numbers below refer to the step numbers on the diagnostic table.
  1. <LI value=4>This step tests for a short to ground in the MIL control circuit. With the powertrain control module (PCM) disconnected and the ignition ON, the MIL should be OFF.
    <A name=TD05>
  2. This step tests for a short to voltage on the MIL control circuit. With the fuse removed, there should be no voltage on the MIL control circuit.
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
Connector End View Reference: Engine Controls Connector End Views or Powertrain Control Module (PCM) Connector End Views
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
  1. <LI type=1>Verify whether the instrument cluster is operational. If the instrument panel (IP) is completely inoperative, refer to
Diagnostic System Check - Instrument Cluster in Instrument Panel, Gages and Console.
Command the MIL ON and OFF with a scan tool.
Does the MIL turn ON and OFF when commanded with a scan tool?
Go to Step 3
Go to Step 4
3
  1. <LI type=1>Observe the Freeze Frame/Failure Records for this DTC. <LI type=1>Turn OFF the ignition for 30 seconds. <LI type=1>Start the engine.
  2. Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records.
Does the DTC fail this ignition?
Go to Step 4
Go to Intermittent Conditions
4
  1. <LI type=1>Turn OFF the ignition. <LI type=1>Disconnect the powertrain control module (PCM). Refer to
Powertrain Control Module (PCM) Replacement .
Turn ON the ignition.
Is the malfunction indicator lamp (MIL) OFF?
Go to Step 5
Go to Step 10
5
  1. <LI type=1>Remove the fuse that supplies voltage to the IPC.
  2. Measure the voltage from the MIL control circuit in the PCM harness connector to a good ground.
Is the voltage less than the specified value?
1 V
Go to Step 6
Go to Step 11
6
  1. <LI type=1>Turn OFF the ignition. <LI type=1>Install the fuse that supplies voltage to the MIL. <LI type=1>Turn ON the ignition, with the engine OFF.
  2. Connect a 3-amp fused jumper wire between the MIL control circuit of the PCM harness connector and a good ground.
Is the MIL illuminated?
Go to Step 9
Go to Step 7
7
Test the MIL control circuit for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct a condition?
Go to Step 14
Go to Step 8
8
Test for an intermittent and for a poor connection at the IPC. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 12
9
Test for an intermittent and for a poor connection at the PCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 13
10
Test for a short to ground in the MIL control circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
11
Repair the short to voltage in the MIL control circuit. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 14
12
Replace the IPC. Refer to Instrument Panel Cluster (IPC) Replacement in Instrument Panel, Gages, and Console.
Did you complete the replacement?
Go to Step 14
13
Replace the PCM. Refer to Powertrain Control Module (PCM) Replacement .
Go to Step 14
14
  1. <LI type=1>Clear the DTCs with a scan tool. <LI type=1>Turn OFF the ignition for 30 seconds. <LI type=1>Start the engine.
Did the DTC fail this ignition?
Go to Step 2
Go to Step 15
15
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Document ID# 855341
2004 Chevrolet Chevy C Silverado - 2WD
Thanks for the help!
Share this post
Link to post
