Mighty HD
Need Torque Specs For 14-bolt Axles
07 classic sierra 2500hd, 4.10's 10.5" rear 14 bolt full float. Had to pull the axles to balance the tires on the truck. Need to know the torque specs.
I'm pretty sure they're the same for 04-07classic.
Thanks
Share this post
Link to post
I don't under stand why you had to pull the axles to balance the tires, but here are the bolt specs
Fastener Tightening Specifications
Application
Specification
Metric
English
Axle Flange Bolt (10.5 Inch Axle)
156 N·m
115 lb ft
Axle Flange Bolt (11.5 Inch Axle)
185 N·m
136 lb ft
Bearing Cap Bolt (8.6 Inch Axle)
75 N·m
55 lb ft
Bearing Cap Bolt (9.5/9.5 Inch LD Axles)
85 N·m
63 lb ft
Bearing Cap Bolt (10.5 Inch Axle)
185 N·m
136 lb ft
Bearing Cap Bolt (11.5 Inch Axle)
207 N·m
153 lb ft
Brake Backing Plate Bolt
135 N·m
100 lb ft
Brake Hose Bracket Bolt
22 N·m
16 lb ft
Brake Pipe Bracket to Rear Axle Bolt
22 N·m
16 lb ft
Brake Pipe Bracket to Rear Axle Nut
13 N·m
115 lb in
Brake Pipe Junction Block Bolt
22 N·m
16 lb ft
Differential Bearing Adjuster Nut Lock Bolt (9.5/9.5 Inch LD Axles)
26 N·m
19 lb ft
Differential Bearing Adjuster Nut Lock Bolt (10.5 Inch Axle)
27 N·m
20 lb ft
Differential Bearing Adjuster Nut Lock Bolt (11.5 Inch Axle)
27 N·m
20 lb ft
Fill Plug
33 N·m
24 lb ft
Flex Hose Bracket Bolt
12 N·m
106 lb in
Pinion Gear Bearing Retainer Bolt (10.5 Inch Axle)
88 N·m
65 lb ft
Pinion Shaft Lock Bolt (8.6 Inch Axle)
36 N·m
27 lb ft
Pinion Shaft Lock Bolt (9.5/9.5 Inch LD Axles)
50 N·m
37 lb ft
Propeller Shaft Yoke Retainer Bolt
25 N·m
18 lb ft
Rear Axle Housing Cover Bolt
40 N·m
30 lb ft
Ring Gear Bolt (8.6 Inch Axle)
120 N·m
89 lb ft
Ring Gear Bolt (9.5/9.5 Inch LD Axle)
140 N·m
103 lb ft
Ring Gear Bolt (10.5 Inch Axle)
165 N·m
122 lb ft
Ring Gear Bolt ( 11.5 Inch Axle)
237 N·m
175 lb ft
Shock Absorber Nut - Lower
95 N·m
70 lb ft
Stabilizer Shaft Link Bolt
95 N·m
70 lb ft
Stabilizer Shaft U-bolt Nut
32 N·m
24 lb ft
U-bolt Nut
72 N·m
53 lb ft
U-bolt Nut (25/35 Series)
150 N·m
110 lb ft
Wheel Hub Nut (10.5/11.5 Inch Axles)
70 N·m
52 lb ft
Tighten the wheel lug nuts
190 N·m
140 lb ft
Share this post
Link to post
Thanks guys.
When I had the tires trued, they balance them on the vehicle. They use a strobe light and a device that spins the tire up. Since I have a G80, it would either explode, or xxxxxxxx? So I suggested to pull the axles to be able to spin it up....
Share this post
Link to post
