rbarger
Whining Fuel Pump On Tahoe
I have a 1999 Chevy Tahoe. The fuel pump makes a loud whining noise. Do I need to replace the fuel pump, or is there something else I can do?
Share this post
Link to post
check your inline fuel filter.....although the fuel pump on my Y2K burb has been whining when it gets really hot ambient temps. for years with no ill effects.
Seems to do it the most after a long hot trip pulling my RV....
dealer technicians said not to worry....and that was almost 8 years ago. So I guess they were right.
Share this post
Link to post
I don't know how old the filter is. I just bought the vehicle a few months ago. It has 92k miles. I haven't had any issues other than the whining noise. It seems to be getting a little worse though.
Thanks for the responses.
Share this post
Link to post
I have a 99 tahoe w/ 101k miles on it. We bought it w/ 32k miles on it and the pump made whining noise. Took it in and the dealership said that was normal for that year. It is getting slightly worse. My mechanic says it is starting to go. it could be tomorrow or 50k miles from now. At 95k miles the gas gauge stopped working. Stuck on full which is happens as the pump goes out. The sending unit in the tank controls it all. Have to drop the tank to fix. I would just keep driving it. Fix it when it actually starts to fail. that what was recommended to me.
Share this post
Link to post
There are some cases where a treatment of Lucas Upper Cyl Lube (fuel treatment) will eliminate or reduce the whinning noise. No promises but the stuff is inexpensive and will help in other areas even if it does not stop the noise. I would get a qt, run it at 5 ozs of LCS to 10 Gallons of fuel for the first tank or two and then reduce it to 3 ozs per 10 gallons.
I would also agree that you need to change the Fuel Filter if you do no know how long it has been in there. There also seems to be no relationship between the whinning noise and the pump going out.
Share this post
Link to post
Not knowing how old the filter is is the perfect reason for changing it! Then you will know how old it is. Plus, it may be making the pump work harder and cause it to fail.
Share this post
Link to post
I've never been a fan of in-line fuel filters. They almost seem to cause more problems than they're worth.
Share this post
Link to post
I cannot think of anyway around them? You would certainly see injector and/or pres. regulator problems if you did not have a good filter in place.
Share this post
Link to post
Bought my 99 Suburban brand new with 2 miles on it. The fuel pump was whining then. It honestly didn't seem any worse to me the day it failed at about 150k. Nobody shoot me here, but I NEVER changed the fuel filter. Never occurred to me that I needed to. I never had any warning that it was going bad. I backed it out of the driveway and parked on the street to do some yard work. Went back later to pull it back in and it wouldn't start. A free tow and $500 later, I had a new fuel pump. Not cheap due to its location in the fuel tank.
What little advice I can offer is that its gonna whine so drive it til it fails. Looking at it now, changing the fuel filter sure can't hurt.
Share this post
Link to post
Sorry; I should have been more specific. I meant the aftermarket in-line fuel filters that a lot of places sell. Their filtration characterisitics are usually pretty bad and I know of many people who have experienced problems when using them.
Share this post
Link to post
The pump on my 01 Silverado whined from day one and was still going strong at almost 100K when I sold it. I know the guy that bought it (he's a member here) and it is still going. Apparently it isn't a very good indicator of the pump going out.
Share this post
Link to post
Mine was whining pretty noticeable when I got my truck at 90,000 miles.
It was BAD when I was sitting for a long time idiling in the taco bell drive thru.
I changed my filter, and although it still can be heard a tiny bit, I cant hardly hear it!
Hasnt been bad since.
And I have very sensitive hearing, but cant hardly hear it.
Share this post
Link to post
