:crackup:
Does anyone out there know what the torque spec is on the oil pan drain plug
on a Chevy Silverado GMT900 4.8L LY2 engine. Can't find it in the owners manual,
unless I missed it.
Share this post
Link to post
Just tighten it until it strips, then back it off 1/2 turn. :crackup: J/K That was my Dad's answer to any such question. Sorry for the intrusion. :lol:
Share this post
Link to post
:crackup:
unless I missed it.
Not sure on the 4.8L, on the 6.2 Lt is 18 ft-lbs
Share this post
Link to post
Never really thought about this and subsequently never drug a torque wrench under a vehicle during an oil change. I've never stripped an oil drain plug. Is kind-of-tight quantifiable? :crackup:
Share this post
Link to post
That is interesting, here is some info:
gmLogoFlat.gif Service Information
2007 Chevrolet Silverado - 2WD | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 1664083 Fastener Tightening Specifications Application
Specification
Metric
English
Accessory Drive Belt Idler Pulley Bolt
50 N·m
37 lb ft
Accessory Drive Belt Tensioner Bolts
50 N·m
37 lb ft
Active Fuel Management Oil Pressure Relief Valve
27 N·m
20 lb ft
Air Conditioning Drive Belt Tensioner Bolts
50 N·m
37 lb ft
Automatic Transmission Flex Plate Bolts - First Pass
20 N·m
15 lb ft
Automatic Transmission Flex Plate Bolts - Second Pass
50 N·m
37 lb ft
Automatic Transmission Flex Plate Bolts - Final Pass
100 N·m
74 lb ft
Battery Cable Channel Bolt
12 N·m
106 lb in
Camshaft Position (CMP) Actuator Magnet Bolts
12 N·m
106 lb in
Camshaft Position (CMP) Actuator Solenoid Valve - First Pass
65 N·m
48 lb ft
Camshaft Position (CMP) Actuator Solenoid Valve - Final Pass
90 degrees
Camshaft Position (CMP) Sensor Bolt
12 N·m
106 lb in
Camshaft Position (CMP) Sensor Wire Harness Bolt
12 N·m
106 lb ft
Camshaft Retainer Bolts - Hex Head Bolts
25 N·m
18 lb ft
Camshaft Retainer Bolts - TORX Head Bolts
15 N·m
11 lb ft
Camshaft Sprocket Bolt - First Pass
75 N·m
55 lb ft
Camshaft Sprocket Bolt - Final Pass
50 degrees
Connecting Rod Bolts - First Pass
20 N·m
15 lb ft
Connecting Rod Bolts - Final Pass
85 degrees
Coolant Air Bleed Pipe and Cover Bolts
12 N·m
106 lb in
Coolant Temperature Sensor
20 N·m
15 lb ft
Crankshaft Balancer Bolt - Installation Pass - to Ensure the Balancer is Completely Installed
330 N·m
240 lb ft
Crankshaft Balancer Bolt - First Pass - Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
50 N·m
37 lb ft
Crankshaft Balancer Bolt - Final Pass
140 degrees
Crankshaft Bearing Cap M8 Bolts
25 N·m
18 lb ft
Crankshaft Bearing Cap M10 Bolts - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap M10 Bolts - Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap M10 Studs - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap M10 Studs - Final Pass in Sequence
51 degrees
Crankshaft Oil Deflector Nuts
25 N·m
18 lb ft
Crankshaft Position (CKP) Sensor Bolt
25 N·m
18 lb ft
Crankshaft Rear Oil Seal Housing Bolts
30 N·m
22 lb ft
Crossbar Bolts/Nuts - 1500 Series
100 N·m
74 lb ft
Crossbar Bolts/Nuts - 2500 Series
120 N·m
89 lb ft
Cylinder Head M8 Bolts - in Sequence
30 N·m
22 lb ft
Cylinder Head M11 Bolts - First Pass in Sequence
30 N·m
22 lb ft
Cylinder Head M11 Bolts - Second Pass in Sequence
90 degrees
Cylinder Head M11 Bolts - Final Pass in Sequence
70 degrees
Cylinder Head Plug
20 N·m
15 lb ft
Differential Carrier-to-Crossbar Nuts
100 N·m
74 lb ft
Engine Block Coolant Drain Hole Plug
60 N·m
44 lb ft
Engine Block Coolant Heater
50 N·m
37 lb ft
Engine Block Oil Gallery Plugs
60 N·m
44 lb ft
Engine Harness Ground Strap Bolt/Stud
16 N·m
12 lb ft
Engine Harness-to-Generator Bracket Bolt
9 N·m
80 lb in
Engine Harness Retainer-to-Intake Manifold Nut
5 N·m
44 lb in
Engine Mount Bracket Through Bolt
100 N·m
74 lb ft
Engine Mount-to-Engine Block Bolts
50 N·m
37 lb ft
Engine Mount-to-Frame Bolts
65 N·m
48 lb ft
Engine Shield-to-Crossbar Bolts
20 N·m
15 lb ft
Evaporative (EVAP) Emission Pipe Bracket Nut
20 N·m
15 lb ft
Exhaust Manifold Bolts - First Pass
15 N·m
11 lb ft
Exhaust Manifold Bolts - Final Pass
20 N·m
15 lb ft
Exhaust Manifold Heat Shield Bolts
9 N·m
80 lb in
Exhaust Manifold Studs
20 N·m
15 lb ft
Flex Plate-to-Torque Converter Bolts - 4L60-E/4L70-E/6L80 Transmission
63 N·m
47 lb ft
Flex Plate-to-Torque Converter Bolts - 4L80-E Transmission
60 N·m
44 lb ft
Front Cover Bolts
25 N·m
18 lb ft
Front Drive Axle Bracket Bolts
90 N·m
67 lb ft
Fuel Injection Fuel Rail Bolts
10 N·m
89 lb in
Fuel Injection Fuel Rail Crossover Tube Bolts
3.8 N·m
34 lb in
Fuel Rail Stop Bracket Bolt
50 N·m
37 lb ft
Generator Bracket Bolts
50 N·m
37 lb ft
Heater Hose Bracket Nut
9 N·m
80 lb in
Ignition Coil Bracket-to-Valve Rocker Arm Cover Studs
12 N·m
106 lb in
Ignition Coil-to-Bracket Bolts
10 N·m
89 lb in
Intake Manifold Bolts - First Pass in Sequence
5 N·m
44 lb in
Intake Manifold Bolts - Final Pass in Sequence
10 N·m
89 lb in
Intake Manifold Sight Shield Retainer Bolts
5 N·m
44 lb in
J 41798 M8 Bolt
25 N·m
18 lb ft
J 41798 M10 Bolts
50 N·m
37 lb ft
Knock Sensor Bolts
25 N·m
18 lb ft
Negative Battery Cable Stud
25 N·m
18 lb ft
Oil Filter
30 N·m
22 lb ft
Oil Filter Fitting
55 N·m
40 lb ft
Oil Level Indicator Switch
20 N·m
15 lb ft
Oil Level Indicator Tube Bolt
25 N·m
18 lb ft
Oil Pan Baffle Bolts
9 N·m
80 lb in
Oil Pan Closeout Cover Bolt - Left Side
9 N·m
80 lb in
Oil Pan Closeout Cover Bolt - Right Side
9 N·m
80 lb in
Oil Pan Cover Bolts
9 N·m
80 lb in
Oil Pan Drain Plug
25 N·m
18 lb ft
Oil Pan M6 Bolts - Oil Pan-to-Rear Housing
12 N·m
106 lb in
Oil Pan M8 Bolts - Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
25 N·m
18 lb ft
Oil Pan Skid Plate Bolts
28 N·m
21 lb ft
Oil Pressure Sensor
35 N·m
26 lb ft
Oil Pump Cover Bolts
12 N·m
106 lb in
Oil Pump Relief Valve Plug
12 N·m
106 lb in
Oil Pump Screen Nuts
25 N·m
18 lb ft
Oil Pump Screen-to-Oil Pump Bolts
12 N·m
106 lb in
Oil Pump-to-Engine Block Bolts
25 N·m
18 lb ft
Power Steering Pump-to-Engine Block Bolts
50 N·m
37 lb ft
Spark Plugs
15 N·m
11 lb ft
Throttle Body Bolts
10 N·m
89 lb in
Throttle Body Nuts
10 N·m
89 lb in
Throttle Body Studs
6 N·m
53 lb in
Timing Chain Tensioner Bolts
25 N·m
18 lb ft
Transfer Case Vent Hose Bracket Nut
20 N·m
15 lb ft
Transmission Housing-to-Engine Bolts/Studs
50 N·m
37 lb ft
Transmission Oil Cooler Line Clip Bolt
9 N·m
80 lb in
Transmission Oil Level Indicator Tube Nut
18 N·m
13 lb ft
Valley Cover Bolts
25 N·m
18 lb ft
Valve Lifter Guide Bolts
12 N·m
106 lb in
Valve Lifter Oil Manifold Bolts
25 N·m
18 lb ft
Valve Rocker Arm Bolts
30 N·m
22 lb ft
Valve Rocker Arm Cover Bolts
12 N·m
106 lb in
Water Inlet Housing Bolts
15 N·m
11 lb ft
Water Pump Bolts - First Pass
15 N·m
11 lb ft
Water Pump Bolts - Final Pass
30 N·m
22 lb ft
© 2008 General Motors Corporation. All rights reserved.
Share this post
Link to post
I didnt know that there were specs until I looked it up.....
Share this post
Link to post
I never really thought about it either after decades of working on my vehicles, but I have a tendency to tighten everything until my wrench breaks or I pull a muscle and there is nothing worse than taking a simple, routine job and turning it into a time consuming nightmare with a stripped bolt. The new oil pans are made of aluminum, with a steel bolt and those aluminum threads will strip a lot quicker than the old iron pans. Maybe I am getting lazy in my old age or possibly wiser but I find myself using a torque wrench for a lot more jobs where the wrong outcome could be disastrous and/or expensive.
Share this post
Link to post
Thanks for the detailed info Mike. I may only use a fraction of them, but at least I know
what has a torque spec. Sure is a lot of them, huh?
Share this post
Link to post
stupid question, how can I make this into a pdf (it is originally a table in DealerWorld) so I can post it on the Wiki???
Share this post
Link to post
I highlighted all of the information and right clicked to copy it, then opened up an Excel spreadsheet
and pasted it in Excel. Once you get it there you can organize, modify or do whatever you want with
it. Then save it as a filename of your choice, in the location of your choice and your done.
You can also save it in Word, wordpad or any other program of your choice. I used Excel because I find it easier
to manipilate & modify.
Share this post
Link to post
Ok, I have to chime in on this one. Even if there is a torque spec for an oil pan drain plug, that torque spec will be most likely for dry threads, and that will not be the case here. Oiled threads will decrease the friction in threads to the point where the preload on the bolt will be practically twice as high as if the threads were dry. About 90% of torque applied to a bolt goes toward overcoming the friction in the threads, and only 10% toward the bolt elongation (in the elastic range).
Translation: do not torque oil pan drain plugs. Only tighten snug with a short ratchet/socket. This is especially important with aluminum oil pans. I tell you, there is a lot of unhappy guys on motorcycle forums who have stripped the threads in their expensive aluminum oil pans by trying to torque the drain plug to "spec".
There is a rubber lined washer under the drain plug. You need to only compress that rubber on the washer sufficiently to get a good seal and tighten the plug enough so it will not back out due to vibration. If an aluminum sealing washer is used, tighten the plug just enough to cut a small groove int he aluminum washer, which will create a positive seal. Do not reuse grooved aluminum or cooper washers, as they may leak if you do not line up the groove right.
I have done hundreds of oil changes on all kinds of vehicles and never stripped the plug threads or had a leak using my method. And I always replace aluminum sealing washers with new ones.
Share this post
Link to post
now here is a stupid question, does the GMT800 series trucks have the aluminum oil pan or is it steel?
Share this post
Link to post
aluminum
Share this post
Link to post
