* - - - - 1 votes
Lt Or P Tires
This topic has been archived. This means that you cannot reply to this topic.
31 replies to this topic
#1 redpete
redpete
  • Member
  • 27 posts
  • Gender:Male
Posted 14 April 2008 - 01:07 PM
I have an 02 Silverado 4x4 extended cab regular(short) box.
The tires I have on the truck right now are P265/75R16.
I live in Minnesota and I pull a boat (medium size aluminum) or a 2 place ATV trailer when we go up north...otherwise it is just driving around the city.
How much towing or hauling does a guy have to do to make the jump to an LT265/75/R16?
Thanks.
#2 Midwestcruiser
Midwestcruiser
  • Validating
  • 122 posts
  • Gender:Male
Posted 14 April 2008 - 01:29 PM
It really depends. If it's used a daily driver without towing/hauling, you're gonna be ok. I know a lot of guys who have "P" tires on their trucks and are quite happy with them. They ride much softer than an "LT" tire.
IMHO, however, I would not recommend going with a "P" tire on a truck, especially if you will tow/haul, even if it's an occasional light load. An "LT" tire is specifically designed for the demands of a truck and its loads. They're constructed much stronger than a "P" tire. You may even be exceeding the weight limit of your current tires. That could spell disaster at any given moment.
Posted Image
'05 Silverado Z-71 Crew Cab 1500 5.3L Vortec V8 Iron Block LM7 G80 Locking Rear Diff
Current Mods - K&N Cold Air Intake with AEM "No Oil" Filter, Vent Visors, Chevrolet Mud Guards, Line-X Bedliner, Roll Tonneau Cover, Clifford Remote Start/Alarm, Bully Tailgate Lock, Scan Gauge II, Reese Brake Controller, Raptor Nerf Bars, Towing/Camper Mirrors
My Garage
#3 redvett
redvett
    Senior Enthusiast
  • Member
  • 3,544 posts
  • Gender:Male
Posted 14 April 2008 - 03:44 PM
If you want to pass more gas stations stay with the "P" rated tires. Less rolling weight and stay with same size.
Edited by redvett, 14 April 2008 - 03:46 PM.
#4 vranasaurus
vranasaurus
  • Member
  • 218 posts
Posted 14 April 2008 - 03:48 PM
The 1500's come with P tires and they can handle the rated limits of the truck.
There is really no reason to go with an LT tire unless you are going to be pushing the limits of your truck on a regular basis.
A medium size boat or a couple of ATV's are no reason to get LT tires.
#5 Bish
Bish
    Senior Enthusiast
  • Member
  • 1,694 posts
Posted 14 April 2008 - 06:20 PM
My thoughts exactly. Don't forget, if you ever tow with P-rated tires, you are supposed to de-rate their load rating by 10% when towing. I look at it as cheap insurance for a truck. Why push the limits of P-rated tires which were put on ONLY to make the soccer moms happy with the street ride. Just another opinion.
2017 GMC Sierra 2500HD Denali Duramax
2011 Cadillac CTS-V Sedan
#6 saskfarmer
saskfarmer
  • Member
  • 822 posts
  • Gender:Male
Posted 14 April 2008 - 06:53 PM
On what surface do you do most of your driving? If you are 90% or more pavement driving, i would suggest sticking with P rather then go with an LT. It will give you a smoother ride, usually is less road noisy, may possible save you a little fuel, and be cheaper to purchase in the first place.
#7 2004GMC1500CC
2004GMC1500CC
  • Member
  • 710 posts
Posted 14 April 2008 - 08:14 PM
Not according to my owners manual. It comes from the factory with P rated tires, and that is what the factory tow ratings are based on.
2004 GMC Sierra 1500 Crew Cab
Escalade Handles
Silverado SS guage cluster
STOLEN Pioneer DEH-P4800MP, PAC SWI-PS, (2) MTX Amps, JL Audio 6.5's in the front door, MTX 10 in a Probox behind the rear seat.
UnderCover Tonneau Cover
Wait4me Performance Tune
Magnaflow #15841 Cat Back Exhaust
Powerslot Plus 14" Front Rotors 29-6890 with Hawk #HB323F.724 Front Brake Pads, Russell 672470 Stainless Steel Brake lines
Summit Sway Control Plus
Cheap Discount Tire Chrome 20's with 275/55/20's.
#8 Bish
Bish
    Senior Enthusiast
  • Member
  • 1,694 posts
Posted 14 April 2008 - 08:27 PM
That's what the tire manufacturers recommend. Don't get me wrong, I'm not trying to suggest it is unsafe towing with P-rated tires. I'm saying there is a significantly better margin for error on LT rated tires and that is how I look at it as cheap insurance. Also, if you run a C load rating or worst case a D, the ride should not suffer significantly. I actually thought performance improved with the stiffer sidewall when cornering. I ran 200K worth of Michilen LTX M/S in a LT265/75R16 LRC on my old Tahoe and those things rode better than the oem P-rated and I had. Also gave me piece of mind when I was towing cross country.
#9 SinisterSS
SinisterSS
  • Member
  • 239 posts
  • Gender:Male
Posted 14 April 2008 - 08:31 PM
P = Passenger car
LT = Light truck
P-series should be illegal to install from the factory; we're not driving cars.
Visit my Garage by Clicking the Black Pearl --> Posted Image
#10 vranasaurus
vranasaurus
  • Member
  • 218 posts
Posted 14 April 2008 - 08:58 PM
If we assume P rated tires are supposed to be derated by 10% when usede in truck applications, we would also have to assume that the manufacturers account for this when desiging the vehicle.
A P265/75/16 is rated at 2840 lbs.
Subtract 10% and you get 2556 lbs.
An LT265/75/16C is rated at 2484 lbs.
An LT265/75/16D is rated at 3074 or 3169 lbs. (depends on the tire)
You have to go to a LR D before you get any additional load carrying capacity out of LT tires vs. P tires.
#11 Bish
Bish
    Senior Enthusiast
  • Member
  • 1,694 posts
Posted 14 April 2008 - 09:07 PM
Correct on many brands of tire. You do get the extra plies on most brands though in the LT's. I think the Michelin's had 3 extra plies in the construction of their LT's versus P's. I think one in each sidewall and one on the main tread. Then again, the 3 may be for a D or Erated. I can never remember these days.
Edited by Bish, 14 April 2008 - 09:07 PM.
#12 MS3DALE
MS3DALE
    Senior Enthusiast
  • Moderator
  • 15,072 posts
  • Name:Rich
  • Gender:Male
  • Drives:'07 Silverado Z71 '11 Camaro SS '02 Saturn SC2
Posted 14 April 2008 - 09:11 PM
6 Plys=Load Range "C"
8 Plys=Load Range "D"
10 Plys=Load Range "E"
Edited by MS3DALE, 14 April 2008 - 09:13 PM.
2015 Silverado Crew-Cab LTZ "Midnight Edition" - 6.2 - 8 spd. - CORSA exhaust - AIRRAID intake tube - 1.5" leveling - HUSKY floor liners - EXTANG full-tilt tonneau - BEDRUG - more to come!!
2011 CAMARO 2SS/RS - LS3/M6 - Inferno Orange Met. - HURST short-throw - Roto-Fab CAI - Kook's LTs - CORSA exhaust - Black Bear tuned (playtoy!)
2012 CRUZE 1LT - Blue Topaz Met. - RS pkg.- Convenience pkg. (work car!)
#13 Zoso
Zoso
  • Member
  • 142 posts
  • Gender:Male
Posted 15 April 2008 - 07:35 AM
This is waht I am curious about. For example, I want to buy BFG A/T's when my OEM tires wear out.
I have P265/70R17 and want to replace with same size of BFG's. However, BFG's do not have P tires...no problem, but BFG A/Ts are only in LR C for that tire size. The P tires i have are rated for just over 2500# the BFG's w/ LR C are rated for just under 2500#.
Would it be wise not to purchase BFG A/Ts then?
GMT900 2007 GMC Sierra 1500 4WD RCLB W/T, 4.8L, 3.42, G80, trailering pkg, spray-in bedliner.
#14 WaterBoyz
WaterBoyz
  • Member
  • 517 posts
  • Gender:Male
Posted 15 April 2008 - 08:19 AM
I had "E's" on my truck.
It was like riding on steel rims.
Felt EVERY little uneven spot in the road.
Running over a worm felt like a broom stick!
Unless you are going to abuse and/or push the limits of your truck (which are not covered in the owners manual) then stay with the OEMs.
#15 saskfarmer
saskfarmer
  • Member
  • 822 posts
  • Gender:Male
Posted 15 April 2008 - 08:37 AM
I would have to disagree.
